Does anyone have a lisp routine that can create a polyline from a given area & one given x or y distance? We have a list of room areas that we must have the exact SF & fit several of these rooms into an existing floor plan. It is very tedious to change a vertex to get the SF.
Have you tried using parametric feature? You should be able to do it, but you need to be good in math 8)
I created this code for regular polygons. Please don't laugh... this is my 2nd AutoLISP code :D
; This LISP will create regular polygon by defining polygon area and number of sides
; Created by Edwin Prakoso
; Website: http://cad-notes.com
(defun c:polyarea (/ n a apt)
 (setq n (getint "\nNumber of Polygon Sides: "))
 (setq a (getreal "\nExpected Area: "))
 (setq apt (sqrt (/ (/ a (/ (sin(/ pi n)) (cos(/ pi n)))) n))) ;calculating apothem for circumscribed polygon
 (setq ptloc (getpoint "\nPick Location: "))
 (command "_POLYGON" n ptloc "C" apt)
Edited by edwinprakoso
