chelsea1307 Posted November 17, 2010 Posted November 17, 2010 Just started using revit mep. Trying to create some custom family's one of them needs like a half dome on top and im just not seeing how i can create this, any suggestions greatly appreciated. Quote
ReMark Posted November 17, 2010 Posted November 17, 2010 Chelsea: Would this be of any value to you? http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9243142&id=13126315&siteID=123112 Quote
chelsea1307 Posted November 17, 2010 Author Posted November 17, 2010 downloading now, thanks I have the general idea of how to make a family just having trouble with the specific shape Quote
chelsea1307 Posted November 17, 2010 Author Posted November 17, 2010 So i figured out one way to do it, no clue if it was the easiest or best way but it got the end result i was looking for made a new work plane so i could sketch in front view then started revolve made half of the overall shape i was looking for (so half of the top half of a circle) and the revolved it around the axis i created in the center of the circle that i was putting the dome on. Quote
rvpas Posted December 2, 2010 Posted December 2, 2010 Hi Chelsea To help you to create a familly you can download a familly guide from autodesk http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394 I have make my first steps to create a revit families with it Good luck Pascal Quote
cadman6735 Posted December 8, 2010 Posted December 8, 2010 Revolve is the correct way to do what you want to do Quote
roof11 Posted January 22, 2011 Posted January 22, 2011 yes i agree sir.. solid form, revolve.. Revolution Properties = 180 degrees. Quote
