dswinty Posted November 15, 2010 Posted November 15, 2010 I just installed Windows 7 and now have a problem with Autocad 2010. Using the scroll wheel on the mouse when I zoom out everything works, but when I try to zoom back in the cross hairs disappear and it will not respond to most commands. I say most because I can close AC and some commands seem to be running on the command line, but not in the work area. The cursor is visible when I go to the ribbon and other other command areas. If I bring up the task manager it says AC is running and then when I close it the cross hairs return. I updated my video and mouse drivers but no help there. Anyone? This is seriously holding me up. I would appreciate any help. Thanks, Quote
dswinty Posted November 15, 2010 Author Posted November 15, 2010 I found the answer and it was that the accelorators where turned off. It seems to be working now although a bit jerky when zooming. Quote
