blueshake Posted November 14, 2010 Posted November 14, 2010 hi.all if I want to get/override some special substring in a big string.what is the most efficient /easy to do this. e.g. I have a string {\H1.1429x;φ}{\H0.7x;\S+0.1^-0.2;\H1.4286x;\C1;(small)} then I want to get the blue part substring.or override the blue part with "replace",what should I do?thanks. Quote
blueshake Posted November 14, 2010 Author Posted November 14, 2010 @Lee.thank you ,I will dig into it. Quote
blueshake Posted November 15, 2010 Author Posted November 15, 2010 hi,Lee after some study,I use the following codes to get the value "+0.1" and "-0.2",but it failed ,any comments?? (defun c:tt(/) (vl-load-com) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) (vlax-put-property regex "Pattern" "\\\\S(.*)(\\^|#|\\\\)(.*);") (setq string "{\H1.1429x;φ}<>{\H0.7x;\S+0.1^-0.2;\H1.4286x;\C1;(small)}") (setq result (vlax-invoke-method regex "Execute" string)) (vlax-for x result (setq match (vlax-get x 'Value) idx (valx-get x 'FirstIndex) lst (cons (list match idx) lst) ) ) lst ) Quote
blueshake Posted November 15, 2010 Author Posted November 15, 2010 ok,here are woked codes. but it return the matched string \\S+0.1^-0.2; if I just want to get "+0.1" and "-0.2",what should I do? (defun c:tt(/ regex lst) (vl-load-com) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) (vlax-put-property regex "Pattern" "\\\\S(.[^;]*)(\\^)(.[^;]*);") (setq string "{\H1.1429x;φ}<>{\H0.7x;\\S+0.1^-0.2;\H1.4286x;\C1;(small)}") (setq result (vlax-invoke-method regex "Execute" string)) (vlax-for x result (setq match (vlax-get x 'Value) idx (vlax-get x 'FirstIndex) lst (cons (list match idx) lst) ) ) lst (vlax-release-object regex) ) Quote
Lee Mac Posted November 15, 2010 Posted November 15, 2010 I'm not too good with RegularExpressions, but maybe this is closer? (defun c:tt ( / *error* regex str ) (vl-load-com) (setq str "{\H1.1429x;?}<>{\H0.7x;\\S+0.1^-0.2;\H1.4286x;\C1;(small)}") (defun *error* ( msg ) (LM:ReleaseObject regex) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq regex (vlax-create-object "VBScript.RegExp")) (setq str (caar (LM:RegExExecute regex "\\\\S.[^;]*\\^.[^;]*;" str))) (print (LM:RegExExecute regex "[^S]*\\^[^;]*" str)) (LM:ReleaseObject regex) (princ) ) (defun LM:RegExExecute ( regex pat str / l ) ;; © Lee Mac 2010 (mapcar (function (lambda ( prop value ) (vlax-put-property regex prop value)) ) '(pattern global ignorecase) (list pat actrue acfalse) ) (vlax-for x (vlax-invoke regex 'execute str) (setq l (cons (list (vlax-get x 'value) (vlax-get x 'firstindex)) l)) ) (reverse l) ) ;;------------------=={ Release Object }==--------------------;; ;; ;; ;; Releases a VLA Object from memory via plentiful error ;; ;; trapping ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; obj - VLA Object to be released from memory ;; ;;------------------------------------------------------------;; ;; Returns: T if Object Released, else nil ;; ;;------------------------------------------------------------;; (defun LM:ReleaseObject ( obj ) (vl-load-com) ;; © Lee Mac 2010 (and obj (eq 'VLA-OBJECT (type obj)) (not (vlax-object-released-p obj)) (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-release-object) (list obj) ) ) ) ) ) Quote
blueshake Posted November 15, 2010 Author Posted November 15, 2010 the final one. (defun c:tt ( / *error* regex str ) (vl-load-com) (setq str "{\H1.1429x;?}<>{\H0.7x;\\S+0.1^-0.2;\H1.4286x;\C1;(small)}") (defun *error* ( msg ) (LM:ReleaseObject regex) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq regex (vlax-create-object "VBScript.RegExp")) (setq str (caar (LM:RegExExecute regex "\\\\S.[^;]*\\^.[^;]*;" str))) (setq str (caar (LM:RegExExecute regex "[^S]*\\^[^;]*" str))) (print (LM:RegExExecute regex "[^\\^]+" str)) (LM:ReleaseObject regex) (princ) ) (defun LM:RegExExecute ( regex pat str / l ) ;; ? Lee Mac 2010 (mapcar (function (lambda ( prop value ) (vlax-put-property regex prop value)) ) '(pattern global ignorecase) (list pat actrue acfalse) ) (vlax-for x (vlax-invoke regex 'execute str) (setq l (cons (list (vlax-get x 'value) (vlax-get x 'firstindex)) l)) ) (reverse l) ) ;;------------------=={ Release Object }==--------------------;; ;; ;; ;; Releases a VLA Object from memory via plentiful error ;; ;; trapping ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright ? 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; obj - VLA Object to be released from memory ;; ;;------------------------------------------------------------;; ;; Returns: T if Object Released, else nil ;; ;;------------------------------------------------------------;; (defun LM:ReleaseObject ( obj ) (vl-load-com) ;; ? Lee Mac 2010 (and obj (eq 'VLA-OBJECT (type obj)) (not (vlax-object-released-p obj)) (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-release-object) (list obj) ) ) ) ) ) Quote
Lee Mac Posted November 16, 2010 Posted November 16, 2010 Glad you got there in the end It probably needs a lot more error trapping though... Quote
blueshake Posted November 18, 2010 Author Posted November 18, 2010 hi,Lee: I found another better way to get the value. codes as follows. (defun c:tt(/ regex lst) (vl-load-com) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) ; (vlax-put-property regex "Pattern" ".*\\\\S(.[^;]*)[\\^](.[^;]*);.*") (setq string "<>{\H0.7x;\\S+0.3^+0.5;}") (setq tp (vlax-invoke-method regex "Replace" string "$1")) (setq tm (vlax-invoke-method regex "Replace" string "$2")) (princ tp) (princ tm) (vlax-release-object regex) ) Quote
blueshake Posted November 18, 2010 Author Posted November 18, 2010 base on the same story. but it failed to the below codes.any idea on this??? (defun c:tt(/ regex lst) (vl-load-com) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) ; (vlax-put-property regex "Pattern" ".*%%P(\d*[\\\\.]?\d*).*") (setq string "<>%%P0.05") (setq tp (vlax-invoke-method regex "Replace" string "$1")) ;(setq tm (vlax-invoke-method regex "Replace" string "$2")) (princ tp) ;(princ tm) (vlax-release-object regex) ) Quote
Lee Mac Posted November 18, 2010 Posted November 18, 2010 Nice idea to use the entries from matches collection To fix your issue: ".*%%P(\\d*[\\\\.]?\\d*).*" Quote
blueshake Posted November 24, 2010 Author Posted November 24, 2010 here is an example of using regular expression to add tolerance for dimension in autocad. enjoy it. toleranc.lsp MdiTab18-32.arx.txt toleranc.dcl Quote
fixo Posted November 27, 2010 Posted November 27, 2010 See how to use groups: quickly tested though) (vl-load-com) (defun C:demo (/ elist en string regex result) (setq string (cdr (assoc 1 (setq elist (entget (setq en (car (entsel "\n\t>> Select dimension with tolerance: ")))))))) (setq regex (vlax-create-object "Vbscript.RegExp")) (vlax-put-property regex "IgnoreCase" 0) (vlax-put-property regex "Global" 1) (vlax-put-property regex "Pattern" "(.\\\\[s])(.*?)(\\^)(.*?);(.*?)") (setq result (vlax-invoke-method regex "Replace" string (strcat "$1" "+0.00125" "$3" "-0.0025" "$5;")));<--build replacement here (vlax-release-object regex) (entmod (subst (cons 1 result) (assoc 1 elist) elist)) (entupd en) (princ) ) ~'J'~ 1 Quote
Lee Mac Posted November 28, 2010 Posted November 28, 2010 I believe Fixo is demonstrating the idea of retrieving items from the Matches Collection when using a 'remembered match', i.e.: [color=blue][b]Original: [/b][/color] "[color=green][b]a[/b][b][color=red]b[/color][/b][/color][color=darkorange][b]c[/b][/color] abc abc" [color=blue][b]Pattern:[/b][/color] "[b][color=green](\\S)[/color][color=red](\\S)[/color][/b][b][color=darkorange](\\S)[/color][/b]" [color=blue][b] Replace with:[/b][/color] "[b][color=darkorange]$3[/color][color=red]$2[/color][color=green]$1[/color][/b]" [color=blue][b] Result:[/b][/color] "[b][color=darkorange]c[/color][color=red]b[/color][color=green]a[/color][/b] cba cba" [font=monospace] [/font] Quote
fixo Posted November 28, 2010 Posted November 28, 2010 I believe Fixo is demonstrating the idea of retrieving items from the Matches Collection when using a 'remembered match', i.e.: [color=blue][b]Original: [/b][/color] "[color=green][b]a[/b][b][color=red]b[/color][/b][/color][color=darkorange][b]c[/b][/color] abc abc" [color=blue][b]Pattern:[/b][/color] "[b][color=green](\\S)[/color][color=red](\\S)[/color][/b][b][color=darkorange](\\S)[/color][/b]" [b][color=blue]Replace with:[/color][/b] "[b][color=darkorange]$3[/color][color=red]$2[/color][color=green]$1[/color][/b]" [b][color=blue]Result:[/color][/b] "[b][color=darkorange]c[/color][color=red]b[/color][color=green]a[/color][/b] cba cba" Yes, it's the usual way to substitute substring ~'J'~ Quote
