HI ALL
When I convert DWG to PDF I found this massage and I don’t know how can I fixed or what will effect on my drawing
So any one have any idea about this problem. see the attached file
Do you know where in the drawing the font ´ArialMT´ is used?
It is saying that the font cannot be found. Try switching to a font that most computers do have, like Arial.
The only real problem this may have is just displaying the correct font. It will either default to another font, or not open at all.
The font called Arial was sometimes marketed as Arial MT. They are basically the same.
Rename the text style in AutoCAD from Arial MT to Arial and save the drawing. You should then have no problem plotting it to PDF.
