jbrm Posted November 13, 2010 Share Posted November 13, 2010 for example when i click on "Door - Imperial" i get the message "Source drawing "C:\Program Files\AutoCAD 2010\Sample\Dynamic Blocks\Architectural - Imperial.dwg" for block "Door - Imperial" not found." what do i need to do to fix this??? Quote Link to comment Share on other sites More sharing options...
rkent Posted November 13, 2010 Share Posted November 13, 2010 Did you install sample files when you installed AutoCAD and have you verified the path does exist? Quote Link to comment Share on other sites More sharing options...
jbrm Posted November 13, 2010 Author Share Posted November 13, 2010 i didnt download it so i dont know about the first, how would i verify that it does exist? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 13, 2010 Share Posted November 13, 2010 Sample dynamic blocks are not downloads. Normally they would be loaded as part of the installation process unless you decided on a "custom" installation and neglected to indicate that you wanted them. You can try to fix the problem by running the REPAIR option from the Windows Add/Remove Programs feature just have your installation DVD on hand as you will probably be asked to insert it in the DVD drive at some point. Quote Link to comment Share on other sites More sharing options...
