Untitled.jpgHey, guys!
I need help for the Isocircle, there is kinda a problem
UUntitled.jpgmmm.....When i make an isocircle with the isometric cursor, i want the isocircle to join two dots so that they attach each other, but the problem is that i don't know the formula/length it is supposed to be so that attach.
Is there are way that i could find the length, so that i can attach it will the two dots and make a curve.
Tyvm for helping
Here is the picture
Edited by jwong22
Can you post an image so we can see what you are working with? Thanks.
You could Scale it with Reference point to achieve the proper dimension
I'm hoping there is a better solution than mine. I think Isometric drawing perspective is odd. By that I mean, if you're drawing a tube that is 2" diameter, you have to draw the isocircle and then tangent lines off of that. But a line from the centre of the isocircle can not be offset 1" each side. At the viewing angle I guess the tube is wider.
