Hi Everyone,:)
How Can I UNION Line & Curve in One Surface ... ??
*Find the attached Image to be more Clearly .. :roll:
** I try to make Union Command, but it works only for 3d shapes ...
Thanks,
Er. EGYPisCREW:geek:
First, you can't union all those lines and curves. But, you can use the Pedit command to join them by changing them to a polyline and joining them. Work on that part of the puzzle first.
now I make it ok ... and i have same of this shape is two
but when i make the loft command it said to me : "The selected entities are not valid"
I knew if I waited long enough you'd figure it out on your own. Good work. :)
