basiony Posted November 9, 2010 Posted November 9, 2010 how can I make Trim or Cutting in 3d drawings *** check the attached images ... Quote
ReMark Posted November 9, 2010 Posted November 9, 2010 One possible solution is to try using the SLICE command with the SURFACE option. Quote
Cerberus Posted November 10, 2010 Posted November 10, 2010 You could use the methods stated here: http://www.cadtutor.net/forum/showthread.php?10520-Trim-in-3d&p=59188#post59188 Basiony, you may find the search facility useful for helping you with your queries. Sometimes the answer is already on the forum, you just need to go find it. Quote
basiony Posted November 10, 2010 Author Posted November 10, 2010 Thanks Cerberus, & I'm sorry for noising .. Quote
