hey, autocad 2011 lags like crazy on my computer too. It takes about 5 seconds to select an object, trim, etc. thats how bad it is. Im on windows 7 64 bitz.
im not familiar with customizing settings on my computer. Please tell me step – by – step how to make autocad run smoothly? thanks.. greatly appreciated. Its driving me nuts. with all the time waiting, i could be 4 times more efficient…
From reading about and using AutoCAD with Win7 64 I don't think it is ready for prime time. Autodesk needs to really spend some time getting it to work with 64 bit, but instead they are spending time with the Mac OS instead.
I have had some luck turning every bell and whistle Win7 comes with, themes, effects, etc.
see also http://www.cadtutor.net/forum/showthread.php?54034-Should-I-be-expecting-better-performance&highlight=speed
Here are the details i run autocad on
System featuresOperating system installed
Genuine Windows® 7 Home Premium 64-bit
Processor
AMD Phenom II Triple-Core Mobile Processor N830 VISION Technology from AMD
• 2.1 GHz, Level 2 cache 1.5 MB, Up to 3.6 GT/s system bus running at AC/DC mode 35W
MemoryMemory
4 GB DDR3 (2 x 2048 MB)
Maximum memory
Supports up to 8 GB DDR3 memory
Memory slots
2 user accessible memory slots
StorageInternal drive
500 GB SATA Hard Disk Drive 7200 rpm
Optical drive
LightScribe SuperMulti DVD±R/RW with Double Layer Support
GraphicsDisplay size
43.9 cm (17.3") diagonal HD+ High-Definition LED HP BrightView Display
Display resolution
1600 x 900
Graphics
ATI Mobility Radeon™ HD 5650 Graphics (switchable), up to 2714 MB total graphics memory with 1 GB DDR3 dedicated
  • 4 weeks later...
2011 been running fine on my pc in 2d, but the past several weeks been trying to make the plunge into 3D and it became obvious my pc just can't handle it.
DeskTop:
OP - Windows XP PRO 32bit SP3
CPU - Intel Core2 Quad @ 2.83GHz
Ram - 4 GB (comp shows 3.5)
Graphics - Geforce 9400 GT 512mb
I know a better video card is needed and my be time to upgrade, but it really bothers me that I draw a simple cube and once I add a visual style I start experiencing problems.
I searched the forums and read through most post, but mostly of specs of comps with problems. I think it would be extremly helpful to me and others to see specs of comps that run this program utilizing the 3d capabilities smoothly without any lag.
Thanks in Advance,
Dan
My work computer is similar to your desktop but I haven't noticed any real lagging problems running AC 2011.
Specs:
OS - Windows XP Pro 32-bit SP3
CPU - Intel Core 2 Duo E6700 2.66GHz w/1066FSB
RAM - 4GB DDR2 800MHz
Graphics - nVidia GeForce 8800 GTX 768MB DDR3 PCIe
HD - 73GB 15,000rpm U3SCSI-320
Mobo - Asus P5B Deluxe Intel P965
The specs under my avatar are for my home computer.
Wow very similar, except for the better video card. I suspected that may be my problem and already been researching. Once decided and installed I will post results.
Thanks,
Dan
One other thing I do is when I am going to work in 3D I boot my computer using the 3GB switch as documented by both Microsoft and AutoDesk.
I tried that and it didn't help, maybe with a new video card it will. Now I know why there are so many " What video card to buy" post, the choices are endless. I just found a Nvidia Quadro 600 1024MB DDR3 that was very reasonably priced and is on the Autodesk Supported and recommended list. Once purchased and installed will post back.
I am running Autocad 2011 on my laptop and desktop and I have the same problem on both - anytime I copy and paste or do something of the sort the system freezes and does not do anything for a while - literally just stops. Its driving me crazy I cant do any work
I am mainly working on drawings in the 2007 format which I am now using in 2010 format. I didnt update the references or any of the other issues the computer prompts me with because it messes up the drawings. The lines end up shifted and misconstrued.
Is it possible that 07 drawings create extra lag on the 2010 platform ?
Thanks
laptop specs:
Windows 7 64 Bit
i7 820Q
Ati Radeon 5850 - 1Gb of Gddr5 ram
7200 rpm 500 Gb HDD
4Gb of 1330 ram
Desktop -
Windows XP 32 bit
Just stock Dell optiplex 760
Edited by msimm15
  • 2 weeks later...
One thing you can do is update all your drivers. New video and motherboard drivers can help performance big time. Also make sure you have no viruses as well as they can hinder performance.
So it seems its just one file that I have using a lot recently, all the others files are ok.
Thanks
Thanks
What's the drawing file size?
rather small - about 4" I dont know why its acting up, I do know it was done in Autocad 2002, I just deleted any unused layers and purged what I could and that helped a lot.
New to AutoCAD by any chance?
By file size I meant how large in KB's is the file itself? Are we talking 100,000+, or 1.2MB or 35MB or what?
Any xrefs attached?
haha doh ! I didnt realize what I wrote - about 4mb :D
how do I check if there are any xref's attached ? - I know there is at least one - I get an error everytime I open the drawing
If you type in IMAGE in the command line you will get a list of all items referenced to the drawing.
Thanks
If it is just one file that is being cantankerous, run an AUDIT on it first. If it still acts up, one thing I always recommend is to wblock out all of the entities you need into a new drawing file. This rebuilds the drawing database and seems to leave anything that is bugging AutoCAD behind.
do you know how to change the option in which the computer uses more processing power towards programs or background services
SWITCH IT TO BACKGROUND SERVICES
restart, wait for the computer to fully load all services and then launch autocad
right click computer
then advanced system settings,
a system properties window should appear
click on settings under the performance dialog, and then click advanced
thats how it is on windows 7 and i think vista too
