daiharv Posted March 2, 2006 Share Posted March 2, 2006 Hello, I have a lisp programme which converts 3D polylines to 2D polylines. Unfortunately it disgards the elevation/height data. The 3D lines I have are a constant height (they are contours). Does anyone know if its possible to amend the lisp below to retain the height data? ;; CVPOLY.LSP Copyright 1996, 1997 Tony Tanzillo all rights reserved ;; ;; Converts 3D polylines to 2D polylines that lie on ;; the XY plane of the current UCS. (setq filter:3dpoly '( (-4 . " (-4 . "AND>") ) ) (defun get (key alist) (cdr (assoc key alist)) ) (defun UCSZdir () (trans '(0 0 1) 0 1) ) (defun UCSPoint2D (wcspoint) ( (lambda (p) (list (car p) (cadr p) 0.0) ) (trans wcspoint 0 1) ) ) (defun mapvertex (e function / e d rslt) (while (/= "SEQEND" (get 0 (setq d (entget (setq e (entnext e)) '("*")))) ) (setq rslt (cons ( (lambda (function data / e d rslt) (apply function (list data)) ) function d ) rslt ) ) ) (reverse rslt) ) (defun cvpoly (pline / data ucs) (setq data (entget pline '("*"))) (entmake (subst (cons 70 (logand (get 70 data) (~ )) (assoc 70 data) (subst (cons 210 (setq ucs (ucszdir))) (assoc 210 data) (subst '(100 . "AcDb2dPolyline") '(100 . "AcDb3dPolyline") data ) ) ) ) (mapvertex pline '(lambda (data) (if (zerop (logand (get 70 data) 9)) (entmake (list '(0 . "VERTEX") '(100 . "AcDbEntity") (assoc 8 data) '(100 . "AcDbVertex") '(100 . "AcDb2dVertex") (cons 10 (UCSPoint2d (get 10 data))) (cons 70 (logand (get 70 data) (~ 32))) ) ) ) )) (entmake '((0 . "SEQEND"))) (entdel pline) ) (defun C:CVPOLY ( / ss i) (cond ( (not (setq ss (ssget filter:3dpoly))) (princ "\nNo 3D Polylines selected.")) (t (setvar "CMDECHO" 0) (command "._UNDO" "_Begin") (repeat (setq i (sslength ss)) (cvpoly (ssname ss (setq i (1- i)))) ) (command "._UNDO" "_En") ) ) (princ) ) (princ "\nCVPOLY.LSP Copyright 1997 Tony Tanzillo") (princ "\nCVPOLY command loaded.") (princ) ;; END CVPOLY.LSP I'm using AutoCAD 2006. Quote Link to comment Share on other sites More sharing options...
Joro-- Posted March 2, 2006 Share Posted March 2, 2006 Do you need to process 3DPolylines only, or you have simple lines too? I can't fix your lisp but may be I can write a VBA code to convert 3DPolylines to 2DPolylines, taking for elevation the Z-coordinate of the first vertice of each 3DPolyline. Quote Link to comment Share on other sites More sharing options...
daiharv Posted March 3, 2006 Author Share Posted March 3, 2006 Yes i only need to process 3d polylines. If you could write a VBA as described that would be brilliant. Quote Link to comment Share on other sites More sharing options...
Joro-- Posted March 3, 2006 Share Posted March 3, 2006 Try this one. After running the macro you are promptrd to select all the 3dPolylines you want to be turned to 2dPolylines. After the transformation all the newly created objects are being highlighted.Old 3dPolylines are deleted... Sub Convert3To2DPolylinesWithElevation() Dim objEnt As AcadEntity Dim SS As AcadSelectionSet Dim objSS As AcadSelectionSet For Each SS In ThisDrawing.SelectionSets If SS.Name = "MySS" Then ThisDrawing.SelectionSets("MySS").Delete Exit For End If Next ThisDrawing.SelectionSets.Add ("MySS") Set objSS = ThisDrawing.SelectionSets("MySS") objSS.SelectOnScreen If objSS.Count = 0 Then MsgBox "Nothing selected!" Exit Sub End If Dim Coords As Variant Dim objPol As AcadPolyline Dim Cn As Double Cn = 0 For Each objEnt In objSS If objEnt.ObjectName = "AcDb3dPolyline" Then Coords = objEnt.Coordinates For i = 1 To ((UBound(Coords) + 1) / 3) - 1 Coords(3 * i + 2) = 0 Next Set objPol = ThisDrawing.ModelSpace.AddPolyline(Coords) objPol.Elevation = Coords(2) objEnt.Delete Cn = Cn + 1 objPol.Update objPol.Highlight True End If Next MsgBox Cn & " 3dPolyline(s) converted to 2dPolyline(s)" End Sub Quote Link to comment Share on other sites More sharing options...
ARKLisp Posted March 3, 2006 Share Posted March 3, 2006 Hi daiharv, I'll have to analyze more deeply the code you posted to answer your question...however at first glance I could say that you have to modify the function UCSPoint2D. You should try to consider the Z value too ...which is missing in the original syntax: try to substitute the old function with the new "UCSPoint3D" (defun UCSPoint3D () ( (lambda (p) (list (car p) (cadr p) 0.0) ) (caddr p) ) ) I haven't yet tested it inside Autocad, try yourself and let me know...if you like. ciao! ARKLisp http://webspace.omniway.sm/fbattistini/ p.s. I made "SPOLYLINER2005" plug-in for ARKLisp TNT (autolisp/vlisp extension for AutoCAD)... a collection of optimized tools to solve this kind of problems. Quote Link to comment Share on other sites More sharing options...
daiharv Posted March 3, 2006 Author Share Posted March 3, 2006 Hi guys, This is probably a really simple question, but how do I load a marco? ARKLisp- have tried insert you text to the lisp but without any luck. Apologies for not being great with routines, any help you can offer will be greatfully accepted. Tahnks, Daiharv. Quote Link to comment Share on other sites More sharing options...
ARKLisp Posted March 3, 2006 Share Posted March 3, 2006 Don't worry, I can help you... loading autolisp/vlisp macros is very simple, first of all you have to launch Autocad, then you can type at the prompt line the command "_APPLOAD", finally you browse your directories and select the macro to load, you push load button and then 'close'. Modification of autolisp macro requires a minumum knowledge of this language... autolisp is very simple but not "stupid". hear you soon, bye! ARKLisp Quote Link to comment Share on other sites More sharing options...
Joro-- Posted March 4, 2006 Share Posted March 4, 2006 Well, follow these steps to to be able to use the VBA macro I sent to you: 1.Open Autocad (no matter new drawing or not) 2.Tools-->Makro-->VisualBasicEditor - Visual Basic window is opened 3.From the menus: Insert-->Module 4.Copy the macro "Convert3To2DPolylinesWithElevation" from CadTutor window and Paste it in the newly created module (the blank area to the right in the VisualBasic window) 5.File-->Save (browse for a place to save your new project ). Visual Basic proposes you should save it with the name "Project", but it's up to you to choose any name (may be smth more associative like "3dTo2d") Now your new project is loaded. But each time you open a drawing you must load it. You must do it in the AutoCad drawing choosing Tools-->LoadApplication ...Find the already created project and press Load. If you want to have this project automatically loaded each time press "Contents" button and add the prject there too. Close the dialog box To run the macro in Autocad choose Tools-->Macro-->Macros if you have no other projects loaded you will have only one macro there - "Convert3To2DPolylinesWithElevation". Otherwise you have to find it among the others, select it and press Run. If everything is done properly you will be prompted from the CommandLine to select objects onscreen so that the 3dPolylines will be processed Every time you want to use the macro start it from Tools-->Macro-->Macros ... Run Regards: Joro Quote Link to comment Share on other sites More sharing options...
daiharv Posted March 5, 2006 Author Share Posted March 5, 2006 The macro works brilliantly and the instuctions you gave to load it were very clear. many thanks, daiharv. Quote Link to comment Share on other sites More sharing options...
Joro-- Posted March 6, 2006 Share Posted March 6, 2006 You are welcome Quote Link to comment Share on other sites More sharing options...
CarlB Posted March 8, 2006 Share Posted March 8, 2006 Just to show another way to skin the cat, this short, non-elegant lisp will convert a 3dpolyline to 2dpolyline: (defun c:3d2d() (command "_explode" pause "") (command "_pedit" "_m" "_p" "" "_y" "_j" "" "") (princ) ) Quote Link to comment Share on other sites More sharing options...
ASMI Posted March 8, 2006 Share Posted March 8, 2006 > CarlB applause! Quote Link to comment Share on other sites More sharing options...
fuccaro Posted March 9, 2006 Share Posted March 9, 2006 CarlB Please let me to put a finger on that code: (defun c:3d2d() (command "_explode" pause "") (command "_pedit" "_m" "_p" "") (if (= 0 (getvar "peditaccept")) (command "_y")) (command "_j" "" "") (princ) ) Now it works whatever is the value of PEDITACCEPT. I assume that people are using AutoCAD 2k4 or newer because PEDITACCEPT vas introduced in that relase only. It could be tested the ACADVER to see if the version is prior to 2k4 but I don't think that it worth the effort. 1 Quote Link to comment Share on other sites More sharing options...
motee-z Posted February 21, 2009 Share Posted February 21, 2009 hello to all would you pleae modify the lisp to convert 3dpolylines to lwpolyline instead of 2dpolyline because i have lisp to draw banks that use lwpolyline can't recognize 2dpolyline thanks in advanced Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 22, 2009 Share Posted February 22, 2009 Excuse my ignorance if I am wrong, but I thought that a 2DPolyline was an LWPolyline Quote Link to comment Share on other sites More sharing options...
David Bethel Posted February 22, 2009 Share Posted February 22, 2009 motee-z Look into the CONVERTPOLY command. Lee, Heavy 2D PLOYLINEs still exist. I think that there is a setting to force their creation in lieu of LWPOLYLINEs. -David Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 22, 2009 Share Posted February 22, 2009 Ahh, thanks David for clearing that up. Lee Quote Link to comment Share on other sites More sharing options...
motee-z Posted February 22, 2009 Share Posted February 22, 2009 i don't know how to draw 2dpolyline but the lisp given in this thread give 2dpolyline now you can see the diference if you see the list of each one okay they are flatten both but diferent entity thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 22, 2009 Share Posted February 22, 2009 Hmmm... that may be caused by a variable on your version maybe... because when I run the code posted by Fuccaro I receive a LWpoly... Quote Link to comment Share on other sites More sharing options...
wizman Posted February 23, 2009 Share Posted February 23, 2009 try adjusting 'plinetype' lee. Quote Link to comment Share on other sites More sharing options...
