diarmuid Posted November 3, 2010 Share Posted November 3, 2010 I am currently modelling in two packages, a piping package called PDS which is an Intergraph package. i import these files into Navisworks via an nwc file, no poblem there. it interact correctly with this model. form this i can read the pipe sizes specs etc. in otherowrds it is not a dumb model. When i import the Revit model via the same method. and when i run a clash report beetween the tw, the revit model will trow up two clashes per actual clash. in other words when say a pipe penetrates a wall (a hard clash) it should only really detect it as a single clash (pipe v wall). However, it detects the front face of the wall and the back face of the wall?! Has this happend to anyone out there, and if so have you solved the issue or is it a software glich? Any input on this would be greatlly appreciated Regards Diarmuid Quote Link to comment Share on other sites More sharing options...
