Autocad Text Window Creation Through Lisp
Guest balajibth84
How to Access or Create Autocad Text Window?(Check with this Command "DIM" and Give "STA" )I have Unit the Weights For all entyties.So i will save to one Xls or *.txt format and save to some Mentioned path like C:\Program Files\AutoCAD 2007 means its need to take that values and its need to Display through the Autocad Text Window.Can you help for me?Please see like below mentioned details..This is For sample.
DIMTMOVE 2 Text movement
DIMTOFL On Force line inside extension lines
DIMTOH Off Text outside horizontal
DIMTOL Off Tolerance dimensioning
DIMTOLJ 0 Tolerance vertical justification
At the moment I respectfully decline to help you with this text window creation.
Explain what? How shall I put this? Let's see. It has been said you were provided a lisp routine at another AutoCAD related Help forum (The Swamp?) and you took certain liberties with it when you posted it back here that the original author of the code found objectionable. I couldn't agree with him more. You have also been told numerous times about the rules governing the posting of code here but you appear to ignore them.
I suggest you view the thread I provided a link to and reread it in its entirety beginning at the point where your participation started through to the end. Then reflect on it long and hard.
Guest balajibth84
I am understood.S i am taken from Swamp.So just i am find out that from swamp.Just i am try to cloz that topic with whatever code i am got.I thinked anybody seen back means it will very useful.So only..Sorry for that...
Guest balajibth84
Remark u r understand my help na.Just see the attached *jpg and *.txt.
That """*.txt"""" is my data sample.Its need to Come to that Text window(Like that *.jpg).So i will copy that my data backup to my local.While we are giving the command that notepad(Or Excel as per u r convinient)data need to shown in Autocad text window...So we want to use 4 notepad.Bcoz we are catogorized the usages like below mentioned types.So as per *.txt name we will use that command.Like after command its need to ask *.txt name.Then we are giving ANGLE means that ANGLE notepad data need to shown in Autocad window.
JINDAL BEAMS
INDIAN BEAMS
CHANNEL
ANGLE
thanks in advance.....
Autocad Text Window Creation.txt
Hint: Look in Developer's Help > Autolisp functions
Bonus hint: Look in the "T" category
Guest balajibth84
lpseifert i have seen.but in T catogory there is no option for the Autocad Text Window Creation ....
Is Textbox the same as text window?
Guest balajibth84
S Remark same as Text window.
Guest balajibth84
anybody seen my query???
Yes, 206 views of your query, but are you surprised by the lack of response? Have you gone back and read through your previous threads? Have you forgotten about all the trouble you caused with your multiple accounts, lying, stealing of code and refusal to follow even the simplest of instructions? That type of behavior is not appreciated and will directly affect your ability to get help with your requests.
Please go back and click on the link that ReMark provided in his previous post, in this thread, and read it from start to finish.
Guest balajibth84
Hey Cad64 and remark r u seen this thread?
Yes...I've seen it. So?
Your thread has been viewed 356 times now. If someone was willing to help you, they probably would have done so by now. As I've said before, perhaps it's time for you to learn how to write your own code, rather than continuously asking us to provide it for you. We are not here to serve you or anyone else. We are teachers, and we enjoy teaching those who are eager to learn, but you have not shown a willingness to do anything other than just take what's given and then ask for more. I think this is why you are not receiving any more responses to your requests. I would recommend you get yourself some books on lisp and start learning the basics. Here is a great resource to get you started: http://www.afralisp.net/index.php
If you start learning, and posting code that YOU have written, maybe then you will start getting helpful replies again. Provided you post your code with the proper formatting, which I have mentioned to you many times already.
Good luck to you :)
Guest balajibth84
ok no problem...can you give any basi idea for this???and just say its possible??i will try
As I instructed you previously, please go here: http://www.afralisp.net/index.php and start reading. Once you learn the basics you will start to understand how to create a routine such as the one you are requesting. But you will not be able to write a program like that right away. There is a learning curve that you will have to go through. Start small, writing simple routines to do basic things, and then work your way up to more complex programs.
When you get stuck on something, come back here and start a new thread. Post your code, with the correct formatting, and I'm sure someone will be willing to help you. But please don't start new threads asking for any more code to be provided to you. I don't think anyone is willing to do that for you anymore.
This thread has been cleaned up and is now closed.
This topic is now closed to further replies.
