Noklu Posted October 26, 2010 Posted October 26, 2010 I am looking for a routine to sort contour lines. I am using 3d polylines that I import from Global Mapper. My problem is all of the lines are on one layer. Ideally, I would like to pick a starting elevation (polyline) and have the routine select every 5th contour up and down. Once then are all selected, I can move them to a new layer (like TOPO-INDEX). Some of these sites are hundreds of acres and have significant elevation changes. To do this by hand is VERY time-consuming (and easy to miss some contours). I am not a programmer, but this seems like the type of task that is ideal for a lisp routine. Any help is appreciated. Quote
pBe Posted October 26, 2010 Posted October 26, 2010 (Defun c:elevl (/ i) (vlax-for i (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object))) (if (member (vla-get-ObjectName i) '("AcDbLine" "AcDbArc" "AcDbPolyline" "AcDbLWPolyline" "AcDb2dPolyline")) (if (member (rem (fix (caddr (vlax-curve-getEndPoint i))) 10) '(0 5)) (vla-put-layer i "V-TOPO-MJR") (vla-put-layer i "V-TOPO-MNR") ) ) ) ) This is a good starting point With credit to T.Willey and Pkohut @ theswamp.org Quote
jvillarreal Posted October 26, 2010 Posted October 26, 2010 To get it to work for your 3d polylines, the object name list will have to include "AcDb3dPolyline"...and to extract the elevation: just look up vla-get-coordinates, vlax-variant-value, and vlax-safearray->list. *EDIT* Almost forgot, you'll need to include (vl-load-com) before (vlax-for... Quote
pBe Posted October 26, 2010 Posted October 26, 2010 To get it to work for your 3d polylines, the object name list will have to include "AcDb3dPolyline"...and to extract the elevation: just look up vla-get-coordinates, vlax-variant-value, and vlax-safearray->list. Thats right JV I played around with this code before to suit my needs... you need to do a lot of tweaking for this to work on your dwg, your needs is too specific Quote
lpseifert Posted October 26, 2010 Posted October 26, 2010 Are the contours actually 3DPolylines or are the polylines with an elevation? Quote
jvillarreal Posted October 26, 2010 Posted October 26, 2010 (defun c:elevl (/ i layerlist) (vl-load-com) (foreach x (Setq layerlist '("V-TOPO-MJR" "V-TOPO-MNR")) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 x) (cons 62 7) '(70 . 0) ) ) ) (vlax-for i (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object))) (if (member (vla-get-objectname i) '("AcDb3dPolyline")) (if (member (rem (fix (caddr (vlax-safearray->list (vlax-variant-value (vla-get-coordinates i) ) ) ) ) 10 ) '(0 5) ) (vla-put-layer i (car layerlist)) (vla-put-layer i (cadr layerlist)) ) ) (if (member (vla-get-ObjectName i) '("AcDbLine" "AcDbArc" "AcDbPolyline" "AcDbLWPolyline" "AcDb2dPolyline")) (if (member (rem (fix (caddr (vlax-curve-getEndPoint i))) 10) '(0 5)) (vla-put-layer i (car layerlist)) (vla-put-layer i (cadr layerlist)) ) ) ) ) Quote
Lee Mac Posted October 26, 2010 Posted October 26, 2010 (edited) I want to play too Completely untested of course... (defun c:elevl ( / i ss e l1 l2 ) (vl-load-com) ( (lambda ( layers ) (mapcar '(lambda ( l ) (vla-Add layers l)) (mapcar 'set '(l1 l2) '("V-TOPO-MJR" "V-TOPO-MNR")))) (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) ) (if (setq i -1 ss (ssget "_X" '((0 . "ARC,LINE,*POLYLINE")))) (while (setq e (ssname ss (setq i (1+ i)))) ( (lambda ( layer ) (entmod (subst (cons 8 layer) (assoc 8 (entget e)) (entget e)))) (if (member (rem (fix (caddr (vlax-curve-getEndPoint e))) 10) '(0 5)) l1 l2) ) ) ) (princ) ) Edited October 27, 2010 by Lee Mac Quote
pBe Posted October 27, 2010 Posted October 27, 2010 pBe, I can't get this to work. Try Lee's code, if you notice this line (setq i -1 ss (ssget "_X" '((0 . "ARC,LINE[color=sienna],*POLYLINE[/color]")))) it selects every type polyline you mght have.... and also lines and arcs... you might want to add a prompt for the "range" of elevation to look for.. there are cases were 3dpolylines created with varying z coordinates... though it will be process, it might not give you the result you want. just some of the things to think about on what you want for the end result. Quote
eldon Posted October 27, 2010 Posted October 27, 2010 there are cases where 3dpolylines created with varying z coordinates. Then they would not be contours. Contours by definition are at a constant z value, and this thread is about contours. Quote
pBe Posted October 27, 2010 Posted October 27, 2010 Then they would not be contours. Contours by definition are at a constant z value, and this thread is about contours. Riiiiggghhhhhtttt..... what i meant is if by chance the existing drawing includes such entities , then it should be ignored by the routine, otherwise create a sub to deal with it. Good point though Quote
Lee Mac Posted October 27, 2010 Posted October 27, 2010 Nice routine as usual Lee Thanks mate, yours isn't bad either Quote
alanjt Posted October 27, 2010 Posted October 27, 2010 (defun c:ContourLabel (/ l1 l2 ss) ((lambda (layers) (mapcar (function (lambda (var lay) (set var (vla-get-name (vla-add layers lay))))) '(l1 l2) '("V-TOPO-MAJR" "V-TOPO-MINR") ) ) (vla-get-layers (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) ) (if (setq ss (ssget "_:L" '((0 . "*POLYLINE")))) (progn (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*)) (vla-put-layer x (if (zerop (rem (caddr (vlax-curve-getEndPoint x)) 5.)) l1 l2 ) ) ) (vla-delete ss) ) ) (princ) ) Quote
Noklu Posted November 10, 2010 Author Posted November 10, 2010 I am overwhelmed! Thank you to everyone. I am able to get Lee Mac's and pBe's to work. I'm having a little trouble with alanjt's. This is a big time saver! Quote
alanjt Posted November 10, 2010 Posted November 10, 2010 Out of curiosity, what problem are you having with mine? I tested it after writing and it worked fine. Quote
marsspyder Posted November 12, 2010 Posted November 12, 2010 Similar to this, is it possible to further sort (polyline) contours into smaller increments? Ex: I need to sort contours ranging from -7 to 4 into .25 increments. I have been sorting them by hand thus far, but after about the 53rd acre, it's getting a little old. If anyone could help me with a lisp, I would be eternaly grateful Quote
Noklu Posted November 12, 2010 Author Posted November 12, 2010 (edited) alanjt, I have to apologize. I tried your routine several times and it would not load. I went back and checked it, when I copied and pasted it, a bit from the end was cut off. I fixed it and re-ran it, everything works perfectly. A couple of comments. I like the idea of selecting the objects. With Lee's routine, the color of the contours change (to dark gray). The contours always seem to come in from the GIS software as all black. The change in color is nice because it is a visual confirmation something happened. Want would be better.... if the major and minor layers were different colors. Like topo-major is dark gray ( and topo-minor is light gray (9). Then it would be easier to read and is closer to how it is actually used. Thanks very much. You guys are amazing. Edited November 14, 2010 by Noklu Quote
lpseifert Posted November 12, 2010 Posted November 12, 2010 Similar to this, is it possible to further sort (polyline) contours into smaller increments? Ex: I need to sort contours ranging from -7 to 4 into .25 increments. I have been sorting them by hand thus far, but after about the 53rd acre, it's getting a little old. If anyone could help me with a lisp, I would be eternaly grateful Since you're from PA and I've got close ties to Mars (Mars, PA that is), try this No error control and the layer needs to be in the dwg (defun c:test () (vl-load-com) (setq bas (getreal "Enter base elevation: ") ci5 (* 5 (getreal "Enter contour interval: "));every 5th contour indexed ss (ssget '((0 . "*polyline"))) idx -1 ) (repeat (sslength ss) (setq obj (vlax-ename->vla-object (ssname ss (setq idx (1+ idx))))) (if (zerop (rem (vlax-get obj 'Elevation) ci5)) (vlax-put obj 'Layer "CONT-IDX");change layer name to suit ) ) (princ) ) 1 Quote
oliver Posted November 13, 2010 Posted November 13, 2010 hi..guys..good day..the lisp was post above it was very useful..and i appreciate that..one thing i need the lisp for computing the volume. Oliver Quote
