creating profiles from 2d survey
Hi guys
I have a 2d Survey, and the Engineer wants some sections through it. I am wondering what the best way to do this is? For now, I am just going to manually put the z value of the spot levels to the correct level in the properties, so I have some sort of 3d info to go with to create the surface model. But would be great if someone could help me if there is a better way of doing this?
Cheers
Martin
If it's a 2D survey, how do you know the elevations of the spots? What kind of 'raw' data do you have?
Hi
I have spot levels on the drawing. Each spot level has 2 block att's. 1 is the cross sign (+), and the other is the level. These are seperate block att's.
Cheers
If you have access to Civil 3D you could try Surfaces > Utilities > Move Blocks to Attribute Elevation. Then you could create a surface using the blocks (Drawing Objects) as a definition.
