Chanell DP Posted September 17, 2008 Posted September 17, 2008 I need to know how to convert points to an XML format, how do I do this? Thanx:cry: Quote
rkmcswain Posted September 17, 2008 Posted September 17, 2008 You don't actually convert the points to XML, because the C3D points remain intact. You can export a copy of them to a LandXML file, using the steps here (this is for 2007, but 2009 should be almost the same) http://management.cadalyst.com/cadman/article/articleDetail.jsp?id=397557 Quote
BOB'27T Posted September 17, 2008 Posted September 17, 2008 File > export > export to LandXML > select points Quote
