Lee Mac Posted October 22, 2010 Share Posted October 22, 2010 one more query while you're at it... (setq dd '("8" "11" "8" "9" "10" "11" "7" "12") n_lst (LM:UNIQUE dd)) ("8" "11" "9" "10" "7" "12") (mapcar 'chr (vl-sort (mapcar 'ascii dd) '<)) ("1" "7" "8" "9") why is it ignoring "11" & "12"? As I said, the vl-sort method should really be used for removing duplcates - re-read my post #8 The reason it ignores 11 and 12 is because that method looks at the Character code of the first character - in this case 11 and 12 are the same = 1. Quote Link to comment Share on other sites More sharing options...
pBe Posted October 22, 2010 Author Share Posted October 22, 2010 i could do it this way... (defun c:sort_test () (setq ls_vl '("12" "2" "C" "A" "4" "B" "5" "6" "7" "D" "8" "9" "E" "10" "11" "1")) (foreach dg ls_vl (if (> (atoi dg) 0) (setq N_ls (cons (atoi dg) N_ls)) (setq L_ls (cons dg L_ls)) ) ) (setq L_ls (vl-sort L_ls '<) n_ls (mapcar 'itoa (vl-sort N_ls '<))) (princ L_ls)(princ N_ls)(princ) ) after removal of duplicates i'll run this What do you guys think? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 22, 2010 Share Posted October 22, 2010 Here's the iterative version of my earlier post - not much difference in performance really: (defun LM:Unique_iter ( l / r ) (while (setq x (car l)) (setq r (cons x r) l (vl-remove x (cdr l)))) (reverse r) ) (defun LM:Unique ( l ) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))) ) List Length: 1280 Benchmarking ................Elapsed milliseconds / relative speed for 8192 iteration(s): (LM:UNIQUE L)........................1747 / 7.38 <fastest> (LM:UNIQUE_ITER L)...................1748 / 7.37 (REMOVEDUPLICATES L).................4602 / 2.80 (MIP_MAKEUNIQUEMEMBERSOFLIST L).....12885 / 1.00 <slowest> List Length: 1280 Benchmarking ................Elapsed milliseconds / relative speed for 8192 iteration(s): (LM:UNIQUE_ITER L).....1716 / 1.01 <fastest> (LM:UNIQUE L)..........1732 / 1.00 <slowest> Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 22, 2010 Share Posted October 22, 2010 If its just a case of sorting, why not: (acad_strlsort (LM:Unique <list>)) Quote Link to comment Share on other sites More sharing options...
pBe Posted October 22, 2010 Author Share Posted October 22, 2010 (edited) if i use that Lee here's the result (acad_strlsort (LM:Unique ls_vl)) ("1" "10" "11" "12" "2" "4" "5" "6" "7" "8" "9" "A" "B" "C" "D" "E") see where "10" and "11" is? for some reason i cant explain i need the list to be in order and in string format... plus i need to work on tracking missing number/letter tooi.e ("1" "2" "4" "5" "A" "B" "C" "E") something like that No worries Lee Mac.. really like the way you write codes though.. complex but short (really short) i think i'm happy with the sorting code i wrote... thanks a mil everyone You know what guys i just realized something.. i really dont need the number list to be in order as a string.. my goal in the first place is grab the last number.. i just leave it as an integer list and grab the highest number using max how di i miss that.. but then again.. thank you for the cool duplicate removal Lee Edited October 22, 2010 by pBe Light bulb on my head Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 22, 2010 Share Posted October 22, 2010 Ah yes, apologies - I didn't realise acad_strlsort also sorted like that - that'll teach me to test it before I post.. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 22, 2010 Share Posted October 22, 2010 How about something like: (defun Sort ( l ) (vl-sort l (function (lambda ( a b / c d ) (if (and (setq c (distof a)) (setq d (distof b))) (< c d) (< a b) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
pBe Posted October 24, 2010 Author Share Posted October 24, 2010 How about something like: (defun Sort ( l ) (vl-sort l (function (lambda ( a b / c d ) (if (and (setq c (distof a)) (setq d (distof b))) (< c d) (< a b) ) ) ) ) ) Again, you made it shorter than what i had... How do you do it Lee I noticed you used lambda from time to time.... boy.. i'm petrified of it , i never used it, no wonder my codes are a mile long... i've seen it on C and Python language maybe bacause i dont really understand it Mathematics is killing me.... Thank you Lee Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 24, 2010 Share Posted October 24, 2010 Thanks pBe, You've nothing to fear with lambda Maybe take a look at this thread: http://www.cadtutor.net/forum/showthread.php?52127-Mapcar-lambda-Description Quote Link to comment Share on other sites More sharing options...
