Michael83 Posted October 18, 2010 Posted October 18, 2010 Hi all, I just purchased Autocad 2010 and going through the mleader settings I can't figure out which settings will have the mtext come in at a 90 deg. angle. The option to have the text placed for "reading from right" places the text at maybe a 80 deg. angle w/ ortho on. The horizontal setting does its job. Could I be overlooking a setting? Greatly appreciate your suggestions. Quote
CyberAngel Posted October 19, 2010 Posted October 19, 2010 One solution would be to rotate your UCS by 90 degrees. That way, as far as the MLeader command knows, the text is horizontal. You can save the UCS, restore the previous one, and reload the labelling UCS whenever you need it. Quote
jake77777 Posted October 19, 2010 Posted October 19, 2010 Seems logical enough, I'll try that first thing back in the office. Thank you! Quote
