christreeroot Posted October 14, 2010 Posted October 14, 2010 Hello all, I have been given a very large landscape/masterplan produced in 2d using os data, i want to lay this with all the details, hatching etc over the contor data i have in Civil 3d so i can play with it a little and then export to 3dws max for modelling. Is this possible and if so how do i go about it ? Thanks in advance as always CJ :wink: Quote
lpseifert Posted October 14, 2010 Posted October 14, 2010 Maybe if you were to make an image file of the landscape plan you could use Surfaces > Utilities > Drape image Quote
christreeroot Posted October 14, 2010 Author Posted October 14, 2010 Hi thanks for the quick reply, i have done that already but want to be able to edit further as neccesary. Quote
lpseifert Posted October 14, 2010 Posted October 14, 2010 You can't (for example) 'drape' a hatch over a surface, the boundary of a hatch must be in 1 plane. Quote
christreeroot Posted October 14, 2010 Author Posted October 14, 2010 I thought that may be the case, could i remove the hatch etc and lay the 2d polylines over the contours ? Quote
