Guys
can anyone please help me with this routine i made for viewport overide. it needs a lot of improvement
1: i cant make truecolor read from my list '(135,13,135 79,161,99)... if i call the value via (car 'thelist)
it doesnt seem to recognize the value
2. i can see the "LayerProperyOverides" as :vlax-true but where is the data?
3. Vlisp method of toggling from one viewport to another like (ctrl+R)
here is my code:
(defun c:overideme (/ lynm_lst ov_clor Vp_SetlayLst cl_cntds_clr )
(setq lynm_lst '("A-ANNO-TEXT" "A-ANNO-DIMS" "A-ANNO-SCHD")  ; items on this list will change
      ov_clor '(7 8 9))      ; (read-line...) from a txt file
          ; every project different list
(if (= (getvar "Tilemode") 1)
  (setvar "tilemode" 0))
(setq Vp_Set (ssget "_X" '((0 . "VIEWPORT"))))
(setq layLst  (mapcar 'cadr(ssnamex vp_set))
 cl_cnt 0
   layLst (cdr (reverse layLst)))
(foreach vpnm layLst
 (foreach lyn_ lynm_lst
   (setq ds_clr (nth cl_cnt ov_clor))
    (vl-cmdf "vplayer" "color" ;"truecolor"  error
    ds_clr
     lyn_ "s" vpnm "" "")
    (setq cl_cnt (1+ cl_cnt))
   (setq cl_cnt 0)
Thank you :)
Contained in various XRecords in the Extension Dictionary of the layer to which it applies:
(defun LM:GetOverrideData ( layer / data )
 (vl-load-com)
 ;; © Lee Mac 2010
 (if
   (and
     (not
       (vl-catch-all-error-p
         (setq layer
           (vl-catch-all-apply 'vla-item
             (list
               (vla-get-Layers
                 (vla-get-ActiveDocument
                   (vlax-get-acad-object)
               layer
     (eq :vlax-true (vla-get-HasExtensionDictionary layer))
   (vlax-for xRecord (vla-getExtensionDictionary layer)
     (vla-getXRecordData xRecord 'typ 'val)
     (setq data (cons (LM:Variants->DXF typ val) data))
 (reverse data)
;;-------------------=={ Variant Value }==--------------------;;
;;  Converts a VLA Variant into native AutoLISP data types    ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments:                                                ;;
;;  value - VLA Variant to process                            ;;
;;  Returns:  Data contained within variant                   ;;
(defun LM:VariantValue ( value )
 ;; © Lee Mac 2010
 (cond
   ( (eq 'variant (type value))
     (LM:VariantValue (vlax-variant-value value))
   ( (eq 'safearray (type value))
     (mapcar 'LM:VariantValue (vlax-safearray->list value))
   ( value )
;;------------------=={ Variants->DXF }==---------------------;;
;;  Converts Type and Value Variants to a DXF List            ;;
;;  Arguments:                                                ;;
;;  typ - VLA Variant of Integer type                         ;;
;;  val - VLA Variant of Variant type                         ;;
;;  Returns:  DXF List                                        ;;
(defun LM:Variants->DXF ( typ val )
 ;; © Lee Mac 2010
 (apply 'mapcar
   (cons 'cons
     (mapcar 'LM:VariantValue (list typ val))
Example:
(LM:GetOverrideData "0")
    (102 . "{ADSK_LYR_COLOR_OVERRIDE")
    (335 2129672936 2105828574)
    (420 . -1033608142)
    (102 . "}")
    (335 2129673304 2105827950)
    (420 . -1033493146)
    (102 . "}")
    (102 . "{ADSK_LYR_LINETYPE_OVERRIDE")
    (343 2129671312 2105830054)
    (102 . "}")
    (343 2129671320 2105830062)
    (102 . "}")
    (102 . "{ADSK_LYR_LINEWT_OVERRIDE")
    (91 . 18)
    (102 . "}")
Lee
thank you Lee for the very informative topic :)
