  Agent 31 said:
Thank you all for the help. I will be away most of the day working on some other diagrams for work. I just wanted to let you know I have received everything. I have a quick question though, am I supposed to put that other code into Lee's? Just curious.
My code will (should) function correctly without any modification - the error about which Se7en commented had been fixed in my post #15
  • Replies 27
  • Agent 31
    10
  • Lee Mac
    7
  • asos2000
    4
  • Se7en
    3
Posted Images
  Grant said:
I am assuming the block is not in a Autocad search path so it cannot find it.
I think all you need to do is to write block out the block to an Autocad search path (or make your own in options, Files tab, search file support path). This will make autocad search your drawing and when it does not find it there it should look in the search paths for Autocad and the ones you can create.
Hope this helps
Well the problem with that, the block IS in the support path. I keep the all of my LISPs for work and their associated files (dwgs, dcls, etc...) under the support path. Thats why I can not figure this out.
I am about to try Lee's code though, I will probably respond soon to let everyone know how it works out. Wish me luck!
Lee,
Thank you greatly for the routine you sent out to me. I was quite impressed that you rewrote the entire thing and extremely quickly. I trust you have much experience on this. On that note, do you know of a good reference book I could pick up? I found a few on Amazon, but am unsure what would be good.
Anyone who sees this, feel free to chime in or point me to an appropriate thread, =)
I have posted below, however, the code I worked with on Lee's. I ran it as is, editing the block definitions, different variations, etc... Below are the common errors I keep receiving no matter what I do. Any ideas? :unsure:
  Quote
xblock Block terminal references itself
; error: misplaced dot on input
The part of the code in question;
(defun LM:ForceBlockDefinition ( block / path ext base )
 ;; © Lee Mac 2010
 (setq path  (C:\\Program Files\\AutoCAD 2010\\Support)
       ext   (.dwg)
       base  (terminal))
Well from what i can see you are using Lee's function wrong; The function accepts an argument.
Sorry, i cant help more then that; I dont really understand Lee's code.
EDIT: Should be more specific.
this is wrong.
       ext   (.dwg)
       base  (terminal))
Use like this:
(LM:ForceBlockDefinition "C:\\Program Files\\AutoCAD 2010\\Support\\terminal.dwg")
Agent, are you using the code I attached? If so there should be no need for modification.
As for the earlier subfunction I posted, as Se7en correctly points out, the function is not to be modified, but rather takes arguments (as any other LISP function would).
I have engineered the function to accept any form of the block as an input, i.e. "block" or "block.dwg" or "C:\\Folder\\block.dwg".
May I ask why you would want to modify the subfunction - does my attached code error?
When I use Lee's code without any modification, this is what comes up.
Command: (load"xblock") LM:FORCEBLOCKDEFINITION
Command: xblock Block terminal references itself
*Invalid*
When I use Se7en's modification, this is the error I come up with.
Command: (load"xblock") ; error: syntax error
*Invalid*
And in case you are wondering, yes I changed the name to fit the macros I already have set in place, though I did leave all identifications that links it to Lee.
Any ideas?
Hi Agent,
This is not due to the code, but because of your block.
This usually happens if you have a block saved within a drawing of the same name, i.e. you have a block called 'terminal' in a drawing called 'terminal.dwg' and then you are trying to insert the drawing 'terminal.dwg' into another drawing, causing the error.
The Solution: check for the above case, if so - explode & purge the block definition out of the 'terminal.dwg' and retry the code.
This version no need for cad file
this subroutine create a layer called Point and block called Terminal
Add this line at first of lisp
(defun C:XBLOCK ( / )    ;WHAT DOES "(/ souk)" MEAN?
[color=red](TerminalBlock)[/color]
(setup)
(getboxinput)
And add this subroutine at end of lisp
(defun TerminalBlock ()
 (if (not (tblsearch "LAYER" "Point"))
     (entmake (list
              '(0 . "LAYER")
              '(100 . "AcDbSymbolTableRecord")
              '(100 . "AcDbLayerTableRecord")
              (cons 2  "Point") ;layer name
              (cons 62  2) ;layer color
              '(70 . 0) ; on, unlocked, thawed
 (if (not (tblsearch "BLOCK" "Point"))
     (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0")
  (100 . "AcDbBlockReference") (2 . "Terminal") (10 0.0 0.0 0.0) (70 . 0)))
     (entmake '((0 . "HATCH") (100 . "AcDbEntity") (8 . "POINT")
  (62 . 2) (100 . "AcDbHatch")
  (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "ANSI31")
  (70 . 0) (71 . 0) (91 . 1) (92 . 7) (72 . 1) (73 . 1)
  (93 . 2) (10 -0.06285 0.0 0.0) (42 . 1.0) (10 0.06285 0.0 0.0)
  (42 . 1.0) (97 . 0) (75 . 0) (76 . 1) (52 . 0.0) (41 . 0.03125)
  (77 . 0) (78 . 1) (53 . 0.785398163397448) (43 . 0.0) (44 . 0.0)
  (45 . -0.00276213586401) (46 . 0.00276213586401) (79 . 0)
  (47 . 0.000519971032496) (98 . 1)
  (10 0.001298342685957 0.002354605870909 0.0)))
     (entmake '((0 . "CIRCLE") (100 . "AcDbEntity")
  (67 . 0) (8 . "POINT") (62 . 2) (100 . "AcDbCircle") (10 0.0 0.0 0.0) (40 . 0.06285)))
     (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
