frenkas Posted October 8, 2010 Posted October 8, 2010 Hello, I've made one very useful tool. It's called MLINE SPLIT and you guessed what it does. However it doesn't work on first and second vertices (1 and 2 vertex), and that is real mystery for me. Why are these vertices so different than all the other vertices. Below is my VBA code: Public Sub MLineSplit() On Error GoTo eh Dim ent As AcadEntity Dim p1 As Variant Dim p2 As Variant Dim x As Double Dim y As Double Dim atst As Double Dim min_atst As Double Dim taskas As Double Dim atst_nustatytas As Boolean Dim dblVertices() As Double Dim dblVerticesCnt As Double Dim dblVertices2() As Double Dim dblVerticesCnt2 As Double Dim sset As AcadSelectionSet Dim perdavimui As Variant Dim obj As AcadMLine Dim obj2 As AcadMLine Dim varpnt As Variant Dim krd(2) As Double Dim aa As Integer Dim objEnt As AcadMLine Dim objEnt2 As AcadMLine ThisDrawing.Utility.GetEntity ent, 1, "Select MLINE: " p2 = ThisDrawing.Utility.GetPoint(, "Select the SPLIT point in MLINE: ") x = p2(0): y = p2(1) atst_nustatytas = False dblVerticesCnt = -1 dblVerticesCnt2 = -1 'randam artimiausia If TypeOf ent Is AcadMLine Then 'AcadBlockRef isrinkimas Set obj = ent 'ThisDrawing.SetVariable "CMLSTYLE", obj.StyleName For aa = 0 To UBound(obj.Coordinates) Step 3 'MsgBox Str(obj.Coordinates(aa)) & "," & Str(obj.Coordinates(aa + 1)) & "," & Str(obj.Coordinates(aa + 2)) atst = DistanceBetween(obj.Coordinates(aa), obj.Coordinates(aa + 1), x, y) If (atst_nustatytas = False) Then min_atst = atst atst_nustatytas = True End If If atst min_atst = atst taskas = aa End If Next aa Else MsgBox "Must select MLINE!" Exit Sub End If Set perdavimui = obj.Copy Set obj2 = perdavimui 'Exit Sub For aa = 0 To UBound(obj.Coordinates) Step 3 'MsgBox obj.Coordinates(aa) 'MsgBox obj.Coordinates(aa + 1) 'MsgBox obj.Coordinates(aa + 2) If aa >= taskas Then dblVerticesCnt = dblVerticesCnt + 3 ReDim Preserve dblVertices(dblVerticesCnt) dblVertices(dblVerticesCnt - 2) = obj.Coordinates(aa) dblVertices(dblVerticesCnt - 1) = obj.Coordinates(aa + 1) dblVertices(dblVerticesCnt) = obj.Coordinates(aa + 2) End If If aa dblVerticesCnt2 = dblVerticesCnt2 + 3 ReDim Preserve dblVertices2(dblVerticesCnt2) dblVertices2(dblVerticesCnt2 - 2) = obj2.Coordinates(aa) dblVertices2(dblVerticesCnt2 - 1) = obj2.Coordinates(aa + 1) dblVertices2(dblVerticesCnt2) = obj2.Coordinates(aa + 2) End If Next aa If ThisDrawing.ActiveSpace = acModelSpace Then If dblVerticesCnt >= 5 Then obj.Coordinates = dblVertices If dblVerticesCnt2 >= 5 Then obj2.Coordinates = dblVertices2 Else If dblVerticesCnt >= 5 Then obj.Coordinates = dblVertices If dblVerticesCnt2 >= 5 Then obj2.Coordinates = dblVertices2 End If obj.Update obj2.Update Exit Sub eh: MsgBox "Error number: " & str(Err.Number) & " . Description: " & Err.Description End Sub Quote
