Hello,
I've made one very useful tool. It's called MLINE SPLIT and you guessed what it does. However it doesn't work on first and second vertices (1 and 2 vertex), and that is real mystery for me. Why are these vertices so different than all the other vertices. Below is my VBA code:
Public Sub MLineSplit()
On Error GoTo eh
Dim ent As AcadEntity
Dim p1 As Variant
Dim p2 As Variant
Dim x As Double
Dim y As Double
Dim atst As Double
Dim min_atst As Double
Dim taskas As Double
Dim atst_nustatytas As Boolean
Dim dblVertices() As Double
Dim dblVerticesCnt As Double
Dim dblVertices2() As Double
Dim dblVerticesCnt2 As Double
Dim sset As AcadSelectionSet
Dim perdavimui As Variant
Dim obj As AcadMLine
Dim obj2 As AcadMLine
Dim varpnt As Variant
Dim krd(2) As Double
Dim aa As Integer
Dim objEnt As AcadMLine
Dim objEnt2 As AcadMLine
ThisDrawing.Utility.GetEntity ent, 1, "Select MLINE: "
p2 = ThisDrawing.Utility.GetPoint(, "Select the SPLIT point in MLINE: ")
x = p2(0): y = p2(1)
atst_nustatytas = False
dblVerticesCnt = -1
dblVerticesCnt2 = -1
'randam artimiausia
If TypeOf ent Is AcadMLine Then 'AcadBlockRef isrinkimas
Set obj = ent
'ThisDrawing.SetVariable "CMLSTYLE", obj.StyleName
For aa = 0 To UBound(obj.Coordinates) Step 3
'MsgBox Str(obj.Coordinates(aa)) & "," & Str(obj.Coordinates(aa + 1)) & "," & Str(obj.Coordinates(aa + 2))
atst = DistanceBetween(obj.Coordinates(aa), obj.Coordinates(aa + 1), x, y)
If (atst_nustatytas = False) Then
min_atst = atst
atst_nustatytas = True
End If
If atst
min_atst = atst
taskas = aa
End If
Next aa
Else
MsgBox "Must select MLINE!"
Exit Sub
End If
Set perdavimui = obj.Copy
Set obj2 = perdavimui
'Exit Sub
'MsgBox obj.Coordinates(aa)
'MsgBox obj.Coordinates(aa + 1)
'MsgBox obj.Coordinates(aa + 2)
If aa >= taskas Then
dblVerticesCnt = dblVerticesCnt + 3
ReDim Preserve dblVertices(dblVerticesCnt)
dblVertices(dblVerticesCnt - 2) = obj.Coordinates(aa)
dblVertices(dblVerticesCnt - 1) = obj.Coordinates(aa + 1)
dblVertices(dblVerticesCnt) = obj.Coordinates(aa + 2)
End If
If aa
dblVerticesCnt2 = dblVerticesCnt2 + 3
ReDim Preserve dblVertices2(dblVerticesCnt2)
dblVertices2(dblVerticesCnt2 - 2) = obj2.Coordinates(aa)
dblVertices2(dblVerticesCnt2 - 1) = obj2.Coordinates(aa + 1)
dblVertices2(dblVerticesCnt2) = obj2.Coordinates(aa + 2)
End If
Next aa
If ThisDrawing.ActiveSpace = acModelSpace Then
If dblVerticesCnt >= 5 Then obj.Coordinates = dblVertices
If dblVerticesCnt2 >= 5 Then obj2.Coordinates = dblVertices2
Else
End If
obj.Update
obj2.Update
Exit Sub
eh:
MsgBox "Error number: " & str(Err.Number) & " . Description: " & Err.Description
End Sub
