ReMark Posted October 9, 2010 Posted October 9, 2010 Bobzy20 said: I think the main problem was I didn't read the part where ReMark said, 'start by rotating it'. Another school boy error! Alright now. We'll have no skipping posts now. No jumping ahead of ourselves. Take everything in order and proceed methodically. Quote
Bobzy20 Posted October 12, 2010 Author Posted October 12, 2010 ReMark said: I changed the precision setting for Angle to 0.0000 then did a List of the line I drew How do I change the precision setting for Angle to 0.0000? Quote
ReMark Posted October 12, 2010 Posted October 12, 2010 Bobzy20 said: How do I change the precision setting for Angle to 0.0000? Use the UNITS command. This brings up the Drawing Units dialog window. Look to the right where it says Angle. Quote
Bobzy20 Posted October 12, 2010 Author Posted October 12, 2010 ReMark said: I drew a vertical line at the open end of one leg from quadrant to quadrant. I changed the precision setting for Angle to 0.0000 then did a List of the line I drew. This told me the angle was something like 72.2827. Ok I opened the drawing I sent you and I've drawn a line from quadrant to quadrant at the open end of one leg like in your image FR_1.jpg. I then changed the precision setting for Angle to 0.0000 then did a List of the line I drew but the list doesn't tell me any angle? Quote
ReMark Posted October 12, 2010 Posted October 12, 2010 Taken from your drawing. Command: li LIST Select objects: 1 found Select objects: LINE Layer: "0" Space: Model space Handle = 363 from point, X=1797.1281 Y= 260.5493 Z= -60.5601 to point, X=1797.1281 Y= 279.6007 Z= -66.6465 In Current UCS, Length = 19.0514, Angle in XY Plane = 90.0000 3D Length = 20.0000, Angle from XY Plane = 342.2827 Delta X = 0.0000, Delta Y = 19.0514, Delta Z = -6.0864 Quote
Bobzy20 Posted October 12, 2010 Author Posted October 12, 2010 Ok cheers - I was using a Polyline which I didn't think would make any difference. Anyway I got an angle of 252.2827 so I rotated it -252.2827 and it is now standing upright - wonderful. On to the next part now.... Quote
ReMark Posted October 12, 2010 Posted October 12, 2010 I'll take that as a sign of progress then. Quote
Bobzy20 Posted October 12, 2010 Author Posted October 12, 2010 Ok all done now, that was easy wasn't it! I'll be back! Quote
