KarlT Posted October 4, 2010 Share Posted October 4, 2010 I am using Autocad 2010 and am new to dynamic blocks. I have sucsessfully created many blocsk using the visibility state to be placed in an attribute. I have a new problem. I have many visibility states in my new block of which I want to be able to stretch some to a restricted size and others to differing restricted sizes and my head is shot. Any advice will be very welcome Thanks in advance Quote Link to comment Share on other sites More sharing options...
Jimmy Tin Posted October 5, 2010 Share Posted October 5, 2010 If your using different visibility states, and you have set sizes, it may be easier just to have the varying sizes as different states. However, if you prefer to be able to stretch a certain visibility you will have to add the stretch component to the visibility states you want to use it in. It's a slightly vague explanation but if you let me know what the block is your trying to change and what sort of sizes you are trying to change it to I can explain better. Maybe even send the block through. It would make it easier to explain when I can apply the idea to a particular block. Quote Link to comment Share on other sites More sharing options...
KarlT Posted October 6, 2010 Author Share Posted October 6, 2010 Thank you for getting back to me. I played with for a day then relised I was asking the block to do way to much. I broke it down to to dynamic blocks and now have it working. Again thanks Quote Link to comment Share on other sites More sharing options...
