apachiee Posted October 2, 2010 Posted October 2, 2010 hello to all, could anyone post me a lisp file which can subdivide a line & arc into multiple points as i want, means if a line has a length of 100m i can subdivide it into 10m interval without breaking points, making a line of 100m with 11 points in it... same as with arc too.. i would really appreciate, ur efforts... thanks... Quote
Lee Mac Posted October 2, 2010 Posted October 2, 2010 Not sure if this is what you are looking for? One from my archive... ;;------------------------=={ Segs }==------------------------;; ;; ;; ;; Divides selected objects into an LWPolyline with a ;; ;; specified number of segments ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; (defun c:Segs ( / *error* _StartUndo _EndUndo doc ss ) (vl-load-com) ;; © Lee Mac 2010 (defun *error* ( msg ) (and doc (_EndUndo doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc) ) (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc) ) ) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) *segs (cond ( *segs ) ( 10 ))) (if (and (setq ss (ssget "_:L" '((0 . "ARC,CIRCLE,LWPOLYLINE,SPLINE,LINE,ELLIPSE")))) (progn (initget 6) (setq *segs (cond ((getint (strcat "\nSpecify Number of Segments <" (itoa *segs) "> : "))) ( *segs ))) ) ) ( (lambda ( j / e inc i pts ) (_StartUndo doc) (while (setq e (ssname ss (setq j (1+ j)))) ( (lambda ( inc i / pts ) (repeat (1+ *segs) (setq pts (cons (trans (vlax-curve-getPointatDist e (* (setq i (1+ i)) inc)) 0 e) pts)) ) (if (entmake (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length pts)) (cons 38 (caddar pts)) (cons 70 0) ) (vl-remove-if 'null (mapcar (function (lambda ( d ) (assoc d (entget e)))) '(6 8 39 48 210) ) ) (mapcar (function (lambda ( a ) (cons 10 a))) pts) ) ) (entdel e) ) ) (/ (vlax-curve-getDistatParam e (vlax-curve-getEndParam e)) (float *segs)) -1 ) ) (_EndUndo doc) ) -1 ) ) (princ) ) Quote
Cad64 Posted October 2, 2010 Posted October 2, 2010 You can use the MEASURE command. This will place Nodes on your line or arc which you can snap to, provided you have "Node" selected in your Object Snaps. Quote
apachiee Posted October 3, 2010 Author Posted October 3, 2010 thank u very much Lee, it really has helped me alot only thing i have to do is to edit the drawing entity into polyline & rest it is working fine, thank u very much again... bro ... :) Quote
irneb Posted October 3, 2010 Posted October 3, 2010 I'm also a bit confused. From your OP it doesn't sound as if you want a segmented pline. Maybe I'm just missing something. Otherwise I'd also state: use Measure or Divide. It places point entities along the line / arc / circle / pline / etc. Changing PDMode to something else than 0 makes the points visible as other figures (e.g. PDMode=3 means a point looks like a X) Or you can tell it to place a block instead, rotated along the path or not - usually how I'd have marked chainage points. Quote
