mattrichardson Posted September 29, 2010 Posted September 29, 2010 Hi everyone, Hoping that someone can help. Everytime that I open a file in ACad, there is a pop up box that states that the file is read-only only, even if no-one has the file open it comes up with it everytime. I'm thinking that I may have accidently changed a setting that means that it only reads files in the read-only format??? Or whether I am saving my files in that format? When other people open files that I have worked on the same message appears on there screen. Any tips would be brilliant. Thank you. Quote
Tiger Posted September 29, 2010 Posted September 29, 2010 Right-click on the DWG-icon of your file and un-check the Read-only-box. Now, why this happens, I don't know. Quote
mattrichardson Posted September 29, 2010 Author Posted September 29, 2010 Every single file says that I have permissions to read and write etc, however it still comes up with the pop-up box... I've tried editing the .dwl2??? files as well as I thought that that might be overriding something, I've looked up options as well to see whether I was saving the file as a read-only version. I'm stumped!! Quote
ReMark Posted September 29, 2010 Posted September 29, 2010 You tried to edit a .dwl2 file? Why? Or do you mean you tried to change its properties as well? Maybe it is a problem with the Read-only property of the Folders themselves and not the individual drawing files. Quote
ReMark Posted September 29, 2010 Posted September 29, 2010 This line got me thinking. "When other people open files that I have worked on the same message appears on there screen." So I went to the AutoDesk website and found this regarding newtwork timing issues: http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=2865666&siteID=123112 Quote
KJB Posted September 29, 2010 Posted September 29, 2010 I had AutoCAD crash before and I would get "Read Only" when opening. I found that deleting the drawing locks (*.dwl and *.dwl2) prior to opening resolved my problem. Quote
