Is there anything or anyway that you can do to export a dxf choosing the layouts and layers that you would like to export? For example; I only want to export the model space and the layers which are not frozen.
If you're asking how to export selected entities instead of the entire drawing...
Start the Saveas command
Select DXF as the file type
Select Tools (upper right corner)
Select Options > DXF Options > Select objects
You'll be able to select the objects you want to export
Thank you for replying. I am trying to get the same results as you would with a publishing a DWF. I want to only export the DXF to include only the model space and the layers that are not frozen. There probably isn't a way to do that in AutoCAD.... but maybe there is a software available to do that. I searched the internet and couldn't find anything.
