xTNickx Posted September 27, 2010 Posted September 27, 2010 Hello! I use Autocad Land Desktop 2007 and I would like to start coding for it in ObjectARX. However, I don't seem to find 2007 version... As a side question, what VS should be used for this? I already tried to create a simple arx with VS 2008 and ObjectARX 2006, but autocad complains that: X.arx is incompatible with this version of AutoCAD where X is the name of my dll/arx. Thank you! Nick Quote
BlackBox Posted September 27, 2010 Posted September 27, 2010 Here is a link to register for a license and download the current ObjectARX SDK's. You may have to Google AutoCAD 2007 ObjectARX SDK to find a suitable alternative download location for older SDK's. As I understand it, the current VS (Express/Full) should be sufficient, provided the appropriate SDK. Hope this helps! Quote
xTNickx Posted September 28, 2010 Author Posted September 28, 2010 Thank you for your reply! I have found ObjectARX 2007 at http://download.autodesk.com/esd/objectarx/2007/Arx_All.exe I'll give it a try... Nick Quote
BlackBox Posted September 28, 2010 Posted September 28, 2010 Thanks for posting the link, mate. :wink: Quote
xTNickx Posted September 28, 2010 Author Posted September 28, 2010 Hello! As a note for lost seeker that arrives at this post, I have tried OARX 2007 with VS Express 2008. Everything builds just fine, but Autocad complains: Unable to load X.arx file. So VS 2005 Express is required, maybe.. - followed the advices here for wizard (but didn't have time to check how it works) - and then I have opened the help; put the hello world example into my new project (console, then some tweaks in project properties) and compiled - VC throws LINK : fatal error LNK1104: cannot open file 'mfc80u.lib' (!) - Express => no mfc - provided some mfc folder and the dll/arx was build successfully (probably should provide mfc from VS 2005, but I have no such thing) And I have a running app now telling Hello world to the people Best regards, Nick Quote
