Field- Date- Uppercase
Hi guys;
Can a Date FIELD be set to all caps?
Instead of September 2008- SEPTEMBER 2008?
TIA
haha thats a good question. You have so many different options to indicate the date and you want it in caps :D
I can't see a way of doing this i've just tried and failed.... is there a text style you can use that only uses caps? just a thought?
:D its just that everyting in the TB is uppercase, the date looked out of place... been diggin on this since morning and also "tried and failed".
but maybe that text style or a Font may work.
If not is it possible to create 1?
Cracked it mate :D
Change your text font name to 'Perpetua Titling MT' and make that current.
Hey presto
:D
  JBullseye74 said:
Cracked it mate :D
Hey presto
:D
:( sadly I dont have that font.
but It if that worked ill have a run at google. :) . is that font similar to arial?
thanks for that, its a bit similar. Ill leave that as a last resort if this doesnt work hehe
ive found a similar thread to this problem. check it out.
http://forums.augi.com/showthread.php?t=37389
It uses rtext>diesel , im still trying to get my head around this :geek:
one of our moderators there :shock:
it works! :D :D :D :D
ive used this diesel routine.
$(upper, $(edtime, 0, MONTH YYYY))
Hi, where exactly do I fit that code in FIELD?
tried to input it but I got a fatal error once ive typed the %.
Sorry, im still new to this stuff :)
thanks.
Hi Dave, I tried to input just the
MMMM yyyy %tc1
to match the Field Expression on the lower left part of the screenshot, but once I type in "%" the error occurs.
Im trying to find where i can directly place the entire code posted by ASMI if it is possible.
Field editor isn't need. Just copy blue string to Text, MText or Block Attribute.
:lol: :lol: :lol:
That was soooooooooooooo incredibly...... easy.
and to think ive been scrounging up google for hours trying to find a solution. maybe LISP,CUI etc would be the next step to improve CADing.
Thanks so much for the tip. cheers mate :D
  dbroada said:
I think that is the field code, just type it in as text.
dang, i didnt get what u meant by that :geek:
that would have already solved it :D
  • 14 years later...
  On 9/12/2008 at 7:49 AM, nocturne00 said:
Hi guys;
TIA
Expand
1. DOUBLE-CLICK BLOCK REFERENCE TEXT TO OPEN ENHANCED ATTRIBUTE EDITOR
2. RIGHT-CLICK THE VALUE FIELD AND INSERT FIELD
3. UNDER FIELD CATAGORY NAME CLICK ON DATE, THEN SET THE FORMAT AS NEEDED
PUT "%tc1" WITH NO QUOTES  OR SPACES IN FRONT OF DATE FORMAT TO MAKE IT UPPERCASE
(THIS MEANS TITLE CASE TYPE 1)
4. APPLY CHANGES
EXAMPLE :
%tc1MMM
WILL SHOW MONTH AS THREE LETTERS IN ALL CAPS: I.E. JAN, FEB, MAR, ETC.
HOPE THIS HELPS.
ig: chevy_techno
Edited by chevy_techno
Spelling error
