HockeyCJ Posted September 13, 2010 Posted September 13, 2010 One weird thing I can't seem to figure out, is that when I click on the dimensions that are annotative, they show up in a ton of different sizes and then once you cancel it goes back to the normal size. Do you know how to stop it doing that? Thanks Quote
nestly Posted September 13, 2010 Posted September 13, 2010 If you have a "ton" of scales associated with your dimension, you probably want to turn of ANNOAUTOSCALE as well, since having a million annotation scales for every dimension defeats some of the benefits of annotative dimensions. If you're interested, there's a great screencast tutorial at Autodesk University called "Size Does Matter: Annotative Scale Feature in AutoCAD" and all the online classes from 2009 became available to everyone as of last week. Quote
