Hi everyone,
I want to create this sketch! I have these questions:
1- Can I make it with line command? If answer is negative, with which command I can and how?
2- If I can use line command, how can I put angles? Because in every new line, the line rotate and I must calculate it and its so difficault! :(
Set up Polar Tracking for 15 degrees and 'Relative to last segment'... some thought required but easier
Congrats on your first post, and welcome to the forums!
Is *someone* having trouble with their AutoCAD homework..? :P (Just kidding!)
Yes, you can use the ._line command.
Once you select your start point, enter this: @Distance
Hope this helps!
Edit: Hehehehe!
LINE Specify first point:
Specify next point or [undo]: @35
Resuming LINE command.
Specify next point or [undo]: @40
Specify next point or [Close/Undo]:
Specify next point or [Close/Undo]: @40.18
Specify next point or [Close/Undo]: @30.53
Edited by BlackBox
Hehehehe!
Dear lpseifert,
Thanks so much of your help. This will solve my problem! :)
Thanks RenderMan,
Yes! Im newbie at autocad and at forum but I read most post and learn many things! :) Anyway.... Thanks for your greeting!
