Cadesignpro Posted September 10, 2010 Posted September 10, 2010 I am recently having trouble with a few dimensions not wanting to adjust there position via grabbing the grip at the arrow/extension line intersection. It seems to only happen when the dimensions are:1. created using "continue dimension" 2. Then updating the dimension (to get rid of the angled text leader on a small dimension) 3. Then moving the text, with a grip, to the opposite side of the dimension. After that I can't move the dimension location via grips anymore. If I create the exact same dimensions using "Linear Dimension" I have no problems. Quote
