turkish Posted September 9, 2010 Share Posted September 9, 2010 Hello to everybody, I'm writing my first message as I started developing my first App. The thing is I have a dwg with the same number of paper space layouts and views, and the same viewport for all the paper space's layouts. So the problem is: I'm stuck trying to link the viewport of each layout to the correspondig view. I attach in .txt the code for VB.NET and appreciate if anybody can help me in this very first real project. Thanks for helping.CODES.txt Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 10, 2010 Share Posted September 10, 2010 Are you trying to get a Viewport that has a particular view, or set the view of a particular viewport? In “Sub CloneView()”, what are the settings for the variables in this line: acViewTblRec.CenterPoint() = New Point2d(posX + dimX / 2, posY + dimY / 2) Quote Link to comment Share on other sites More sharing options...
turkish Posted September 10, 2010 Author Share Posted September 10, 2010 Hi Seant, First af all, thanks for your reply. I'm trying to set the view of a particular viewport, but the thing is in de dwg I only have one viewport (the same viewport for all the paper space's layout). If I have understood how Autocad's database works this means than each time I select a different paper space layout, the viewport drawed in this layout becomes the active viewport in the database. So I think that I need to program the next steps: 1) select the right paper space (the new cloned layout) 2) associate the new view created with this paper space (what I suppose sets the view to the viewport). I can send you the cad file so you can have a look (if have spare time ) The settings for the variables are geometrical positions, distances, etc., I send the ones I have for my trial: Dim dimX As Double = 80.586 Dim dimY As Double = 56.232 Dim deltaX As Double = 9.8119 Dim deltaY As Double = 7.803 Dim matX As Integer = 1 Dim matY As Integer = 4 Dim posX As Double = (matX - 1) * (dimX + deltaX) Dim posY As Double = (1 - matY) * (dimY + deltaY) Thank you again for your time. Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 10, 2010 Share Posted September 10, 2010 Each Layout has an initial Viewport, even if there are no “Floating Viewports” present. It’s a rather confusing aspect setup by Autodesk. See this current thread at "The Swamp" : http://www.theswamp.org/index.php?topic=34837.0 I should have some time this weekend so, yes, upload a cad file with all the specific parameters. Quote Link to comment Share on other sites More sharing options...
turkish Posted September 10, 2010 Author Share Posted September 10, 2010 I'll have a look into "the swamp", cause right now I really feel myself sinking into it. I've attached a new txt with very basic instructions of the way to use de dll and the base dwg I have to deal with. I have to generate a whole array of presentations and views but I couldn't get the first milestone as I've told. Thanks.Drawing1.dwg CODES_COMPLETE.txt Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 13, 2010 Share Posted September 13, 2010 I can’t find a straightforward method to assign a “Saved View” to a paperspace viewport. We must be missing something as that really should be possible with the API. I haven’t invested considerable time in a search but . . . . neither is it readily apparent that a viewport’s view can be modified without first activating the Layout. I’ll look into that further when I get time. Would activating the layout first be acceptable to the workflow of your routine? Quote Link to comment Share on other sites More sharing options...
turkish Posted September 13, 2010 Author Share Posted September 13, 2010 Yes, there's no problem to activate the layout first. I haven't solved it yet, so thank you again for your time. Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 13, 2010 Share Posted September 13, 2010 I'll try to get something ready for upload tomorrow. Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 14, 2010 Share Posted September 14, 2010 See if this works out. Warning: Limited Testing! <CommandMethod("AssignView")> _ Public Sub AssignView() '' Get the current database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim myLayoutDictionary As DBDictionary = acCurDb.LayoutDictionaryId.GetObject(OpenMode.ForRead) Dim oid As ObjectId = myLayoutDictionary.Item("E10") Dim myLayout As Layout = DirectCast(acTrans.GetObject(oid, OpenMode.ForWrite), Layout) Dim ltman As LayoutManager = LayoutManager.Current Application.SetSystemVariable("TILEMODE", 0) acDoc.Editor.SwitchToPaperSpace() ltman.CurrentLayout = "E10" Dim oids As ObjectIdCollection = myLayout.GetViewports() Dim vp As Viewport = DirectCast(acTrans.GetObject(oids(1), OpenMode.ForWrite), Viewport) Dim vCenter As Point2d = New Point2d(posX + dimX / 2, posY + dimY / 2) Dim locked As Boolean = vp.Locked If (locked) Then vp.Locked = False vp.ViewCenter = vCenter vp.UpdateDisplay() vp.Locked = locked acTrans.Commit() End Using End Sub Quote Link to comment Share on other sites More sharing options...
turkish Posted September 14, 2010 Author Share Posted September 14, 2010 Great, it works perfect. This is not the method I was trying but it solves my problem. Thank you very much. Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 14, 2010 Share Posted September 14, 2010 Great, it works perfect. This is not the method I was trying but it solves my problem. Thank you very much. The whole process does need more investigation. When time permits, perhaps. Quote Link to comment Share on other sites More sharing options...
daboho Posted August 15, 2021 Share Posted August 15, 2021 (edited) @SEANThow to apply this part: Dim oid As ObjectId = myLayoutDictionary.Item("E10") to C# withhout loop because i has test myLayoutDictionary. Item("E10") in c# no method for item Edited August 15, 2021 by CADTutor Added code to code block Quote Link to comment Share on other sites More sharing options...
CADTutor Posted August 15, 2021 Share Posted August 15, 2021 @daboho note that is topic is more than 10 years old! 1 Quote Link to comment Share on other sites More sharing options...
