David Bethel Posted September 8, 2010 Posted September 8, 2010 Greetings, Is there a way to directly import an Autocad dwg file made of 3DFACEs only into Revit? Thanks -David 3D-MESH.DWG Quote
Jscott85 Posted September 8, 2010 Posted September 8, 2010 Depending in the version of Revit you are using (I am in 09') there is the option file>import/links> Cad Format I am not entirely sure if that is what your looking for, but it allows multiple Cad drawings to be imported. Quote
David Bethel Posted September 8, 2010 Author Posted September 8, 2010 Basically we need to make a symbol in Revit based on AutoCAD geometry. Thanks -David Quote
roof11 Posted January 22, 2011 Posted January 22, 2011 (edited) but i guess for Revit Arch're to 3D MAx is not possible sir. Edited January 22, 2011 by roof11 Quote
