xTNickx Posted September 2, 2010 Posted September 2, 2010 Hello! A little background, first. I have some large number of MrSid (sid files) and coresponding sdw file to tell us informations about where and how the image should be inserted. Such a file is presented below: 1.50000000000000 (X scale, pixel size in meters) 0.00000000000000 (affinity - Y-scale in X dir.) 0.00000000000000 (affinity - X-scale in Y dir.) -1.50000000000000 (Y scale) 1934001.50000000000000 (X coordinate of the upper left pixel) 1187698.50000000000000 (Y coordinate of the upper left pixel) What I would like to build is a "database" that may be searched by a lisp routine. The workflow is as follows: Command: Src_img Please choose a point: are to be inserted> Now, while everything is trivial in this list, I seem to have a hard time retrieving the size of exotic file types (as sid) as it appears in the Autocad environment (wold size, if you wish). For other files I use a trick found on web (VBA): Set objFolder = obj_Shell.Namespace(FilePth) Set objFile = objFolder.ParseName(FileName) objFile.ExtendedProperty("Dimensions") This gives us the size, in pixels. Having the scales presented before, computing coordinate of bottom right corner is, again, trivial. The question, now: Is there a way that you know about to get the size of a sid image (pixels or world size) using lisp or vba? I would go as far as to recursively search the folders for sid files, load them, retrieve the bottom-right corner, unload, step to next. By the way, I have already downloaded the sdk from LizardTech and I'll see what I can get from there. Any insight is greatly appreciated! Have a great day! Nick PS I give you so much informations just to avoid reading things that I already know about. Sorry! Quote
xTNickx Posted September 28, 2010 Author Posted September 28, 2010 Just being here for some ObjectARX info and I have remembered that there was no answer to this. I did this (on Autocad Land Desktop 2007): - an excel sheet (refered by EXCSheet in code) that holds full paths and names for all images on column 1 - FILEDIA set to 0 With EXCSheet i = 4 Do RetryIns: ThisDrawing.SendCommand ("MAPIINSERT" & vbCrLf) ThisDrawing.SendCommand ("""" & .Cells(i, 1).Value & """" & vbCrLf) DoEvents Sleep 2000 ' maybe less ThisDrawing.SendCommand ("N" & vbCrLf) ' answer no ' this is he only image in the drawing (empty drawing) For Each a In ThisDrawing.ModelSpace If (TypeOf a Is AcadRasterImage) Then Set the_img = a insp = the_img.Origin ' insertion may fail to place image If (insp(0) = 0) And (insp(1) = 0) Then the_img.Delete ' if so, we should retry GoTo RetryIns End If Call the_img.GetBoundingBox(minp, maxp) ' you may save bounding box here scl_ty = ThisDrawing.GetVariable("INSUNITS") Call ThisDrawing.SetVariable("INSUNITS", 0) ' save here the_img.Rotation and the_img.ScaleFactor Call ThisDrawing.SetVariable("INSUNITS", scl_ty) ' maybe you need maximum/ minimum values... this is the place the_img.Delete ' no need for this image any more Exit For End If Next a i = i + 1 Loop Until .Cells(i, 1).Value = "" End With The code may look odd, as the parts that save values to excel sheet are stripped, but this is the general idea. Best regards, Nick Quote
