Adman234 Posted August 31, 2010 Posted August 31, 2010 I have an assembly of a small box with added features that I made, and each side of the box is 8 inches in length. I want to 3D print the box, but I obviously do not want the box to be 8x8x8 when printed:) Is there a way to easily "scale down" the box so that it is 1x1x1 when measured in inventor? I am using inventor 2011 I tried searching but could not find anything, thanks for your time. Quote
BIGAL Posted August 31, 2010 Posted August 31, 2010 Why scale it ? just when you print do it at what ever scale you want ? Quote
kencaz Posted August 31, 2010 Posted August 31, 2010 Yes, scale in your idw or (dwg) if you prefer to 1/8 KC Quote
Adman234 Posted August 31, 2010 Author Posted August 31, 2010 hey thanks for the help I am sorry but I am extremly new to inventor. I apreciate your time Adam Quote
jdits7 Posted August 31, 2010 Posted August 31, 2010 If I am reading this correct, you want to print this on a 3D printer. If that is the case go to the Inventor Menu in the upper left hand corner, go down to Print, go to Send to 3D Print Service, then a dialog box will pop up and there you can set the scale that you want it printed in. Pic to show dialog box. Quote
