zeekay Posted August 24, 2010 Author Posted August 24, 2010 dtaylor: Can u just paste screen shot of you version of bottle Quote
dtaylor Posted August 24, 2010 Posted August 24, 2010 ya, that's pretty good. be sure to fix the dome so its a circle. and add a nipple to the center of the dome. Quote
zeekay Posted August 24, 2010 Author Posted August 24, 2010 yes u right but this work done before came here withe the help of extrude>path command in autocad the bottle look not perfect thats y i exported it to 3dmax where i modify vertexes to correct hte shape. Quote
zeekay Posted August 24, 2010 Author Posted August 24, 2010 dtaylor: Did you use Loft to create your version of the bottle? No i use extrude>path Quote
zeekay Posted August 24, 2010 Author Posted August 24, 2010 Any one send me the tutorial link about this problem to educate me. Quote
ReMark Posted August 24, 2010 Posted August 24, 2010 Any one send me the tutorial link about this problem to educate me. I thought you figured it out on your own. My question about using Loft was directed at dtaylor and not at you. Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 I thought you figured it out on your own. My question about using Loft was directed at dtaylor and not at you. Thanks for your reply When I Modeled this bottle I face many problem with lemon shape bcoz I dont know which steps use to create this kind of bottle smothly. I used Extrude command with different path. If you do me more favor send me the tutorial link or video how to creatre and calculate this kind of bottle. I see Ur version of bottle is 1 object with lemon shape How u create that and when i use massprop on ur 3d bottle version is show me : ---------------- SOLIDS ---------------- Mass: 710134.8340 Volume: 710134.8340 Bounding box: X: 386.5078 -- 461.5544 Y: 83.8717 -- 149.1644 Z: -197.9823 -- 73.3740 Centroid: X: 424.0308 Y: 116.5180 Z: -87.4120 Moments of inertia: X: 18424188435.9468 Y: 1.3651E+11 Z: 1.3767E+11 Products of inertia: XY: 35085792103.8611 YZ: -7232772377.8426 ZX: -2.6321E+10 Radii of gyration: X: 161.0734 Y: 438.4404 Z: 440.3020 Principal moments and X-Y-Z directions about centroid: I: 3357046623.7811 along [1.0000 0.0000 0.0000] J: 3399400842.8785 along [0.0000 1.0000 0.0000] K: 346011983.2481 along [0.0000 0.0000 1.0000] Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 Your Unit of Drawing is decimal Factor this was mine too. So Volume: 710134.8340 its in meter i think so what the formule use for this Volume to ML Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 Is this create from loft. Shape of botthe lemon and the neck is circle Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 Dose any one else download the attacment Umer(Working).dwg and make a this bottle tutorial step my step with the ending of calculation in ml Quote
dtaylor Posted August 25, 2010 Posted August 25, 2010 ---------------- SOLIDS ---------------- Volume: 710134.8340 I got this using what you had set up for units. The number above is cubic millimeters. From that its an easy conversion mL. Quote
JD Mather Posted August 25, 2010 Posted August 25, 2010 ..and make a this bottle tutorial step my step.. What is the thickness of the plastic wall (not at the cap fastening, but overall). Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 My unit is decimal. I supose 1 unit of decimal factor is eqal = to 1 milimeter. Now I got the answer 1st conform the 3d model totally complete and Its one object. then use command and select object and enter ---------------- SOLIDS ---------------- Volume: 710134.8340 Now Divided Volume by 1000 V = 710134.8340 / 1000 = 710.13ml Quote
zeekay Posted August 25, 2010 Author Posted August 25, 2010 :)Thanks For Everybody How Reply and give me good tips and tricks. I want How the loft commad use on my bottle drawing Quote
zeekay Posted August 26, 2010 Author Posted August 26, 2010 ya, i just turned that lemon shape into a closed polyline, then just scaled it down to what i needed at various points along the bottle. once i got to the top of the neck i just placed circles. then just lofted everything in the correct order. i just did everything roughly so its not perfectly exact buts its a close approximation and can lead zeekay in a direction if he wants more precise results But dtaylor if you share screen shot of modeling setp by step so that was really easy to understand Quote
ReMark Posted August 26, 2010 Posted August 26, 2010 No step by step is required. dtaylor outlined the basic procedure above. He also points out that it was a "rough" attempt to achieve the desired "lemon shape" of the bottle but more work would be required to get better results. The LOFT command is explained in your AutoCAD Help file as well as your Users Guide. If you search on the word LOFT here I'm sure you'll find further examples of how it works and its usefulness. Quote
JD Mather Posted August 26, 2010 Posted August 26, 2010 But dtaylor if you share screen shot of modeling setp by step so that was really easy to understand How thick is the material? Quote
zeekay Posted August 26, 2010 Author Posted August 26, 2010 How thick is the material? JD The bottle thinkness in the working is about 0.25 or 0.35mm But i just need without thick bottle creation mether bcoz when we use massprop command in Autocad this show volume of mass. If we make bottle with thickness so the mass volumne is not exact same and the calculation of ml is not work. But i Just still need Tutorial how to model this like of bottle shape Quote
JD Mather Posted August 26, 2010 Posted August 26, 2010 But i Just still need Tutorial how to model this like of bottle shape If I bother to make Tutorial I need complete information. My curiosity would be the difference in volume of solid like previously offered in this discussion and true volume. Otherwise the problem doesn't interest me enough to take the time. Quote
ReMark Posted August 26, 2010 Posted August 26, 2010 zeekay: Please provide JDM with the necessary information or withdraw your request for a tutorial. In America we have a saying "Don't look a gift horse in the mouth." JDM has made you a very generous offer. I suggest you take him up on it or you may not see another offer like it in the future. JDM: no offense implied re: saying. Quote
