dubking Posted August 24, 2010 Posted August 24, 2010 hi guys, noob here, been given since Friday to learn CAD, i need to have my work in the post tomos at the latest. my problem is text and plotting, heres a jpeg showing the issue, bottom jpeg (only printer available - lexmark P6350) when i view my project before plotting it is fine jpeg included. many thanks! peace Quote
Slaraffenmann Posted August 24, 2010 Posted August 24, 2010 I don't know what's causing this, but I have seen it before. I our case, the text was written as Multiline text (mtext). We tried to explode the text, and that actually solved the problem. Try to explode the text. Quote
dubking Posted August 24, 2010 Author Posted August 24, 2010 ok, gna sound stupid now, but how does one explode the text? Quote
Slaraffenmann Posted August 24, 2010 Posted August 24, 2010 Click on the text and type explode. :-) Quote
dubking Posted August 24, 2010 Author Posted August 24, 2010 cheers mate, got it printed, one more question, can you think of any other dimensions or info i should include? Quote
Slaraffenmann Posted August 24, 2010 Posted August 24, 2010 Maybe you should include the outer diameter of the rim? Quote
Tankman Posted August 24, 2010 Posted August 24, 2010 Slaraffenmann said: Maybe you should include the outer diameter of the rim? Perhaps that would be givin' away a top secret? Quote
