lownote1980 Posted August 20, 2010 Share Posted August 20, 2010 Hi all, As everyone has been more than helpful in previous posts I thought I'd ask if anyone knew if the following was possible. As a result of onsite coding my data input to CAD is pt number, elevation text, site notes and where appropriate blocks. With the tree blocks I manually scale the crown and trunk via dynmaic block manipulation as below. I wondered if scaling the crown and trunk elements was possible with a lisp routine? Any thoughts how I might go about this would be welcomed. Kind regards as always. Lownote1980 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 20, 2010 Share Posted August 20, 2010 If the scaling is done via Dynamic Block Properties, then certainly these can be manipulated using VLISP. Quote Link to comment Share on other sites More sharing options...
