I need to rename around 100 layers with a prefix. is there a lisp for this??
thanks for your response.
how about adding suffix, how do we do that ?
Perhaps like this:
(defun c:SUFFIX  (/ suffix oldLayerName)
 (vl-load-com)
 (cond
   (*activeDoc*)
   ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))
 (if (setq suffix
    (strcase
  (getstring "\n  >>  Enter Suffix for All Layers: ")))
 (vlax-for x  (vla-get-layers *activeDoc*)
   (if (and
     (not (vl-position
      (setq oldLayerName (strcase (vla-get-name x)))
      '("0" "DEFPOINTS")))
     (not (vl-string-search "|" oldLayerName)))
  (vla-put-name x (strcat oldLayerName suffix)))))
 (princ)) ;_end defun
Or like this:
(defun SUFFIX  (arg / oldLayerName)
 [color=seagreen];; Example: (SUFFIX "-TEST")[/color]
 (vl-load-com)
 (cond
   (*activeDoc*)
   (if (and
     (not (vl-position
  (vla-put-name x (strcat oldLayerName arg))))
isnt it possible with using RENAME command ?
Interesting that you ask... have you tried it? :ouch:
To my surprise, it didn't work for me :o... that's why I quickly wrote the routines for you. :wink:
good thing that u wrote those routins but it wont help me, maybe someone else out there will see some use of those, anyways ofcourse i tried it with RENAME but it didnt work for me either. i thought may be i did something wrong so it didnt work for me and may be someone figured it out tht there is a way to do it with RENAME and that is the reason why i asked if isnt it possible with using RENAME command, so no need to be surprised wise one, by the way thnx for ur effort to write those routins.
I hope I did not offend :huh:; better to ask, rather than assume... You know? o:)
I think it is silly that the RENAME command has this failure to begin with.
Wish I could have been more helpful... Maybe next time!? :wink:
