KennethA Posted September 10, 2008 Share Posted September 10, 2008 I just got a new computer at work, and I moved all my Inventor drawing files to the new computer. But when i open the files in Inventor, bolts, washers and such is missing and it wants me to search Content Center for replacements. This would not be a problem if i only had a few assemblys, but i have hundreds, and every time I open one, i get this screen. What can i do? Is there a "automatic search"? Quote Link to comment Share on other sites More sharing options...
WagglyFawn Posted September 10, 2008 Share Posted September 10, 2008 Are you sure you have the Content Center loaded on this new computer? If you do, do you have all the libraries loaded that you were using previously? Quote Link to comment Share on other sites More sharing options...
KennethA Posted September 10, 2008 Author Share Posted September 10, 2008 Yes, I'm sure. I'm using ANSI, DIN and ISO. I installed the same I had on the old computer. I also have this problem if I work on my laptop at home and transfer the assembly files to my workstation. I've also installed Inventor in the same place I had installed it on the old computer, and I use the same path to my files. Quote Link to comment Share on other sites More sharing options...
Toolish Posted September 11, 2008 Share Posted September 11, 2008 Do you still have access to the old computer? If so, assuming you used default setting for content center location copy the folder from My Documents\Inventor\Content Center Files on the old computer to the same spot on the new computer and see if that helps. you are not using vault are you? Quote Link to comment Share on other sites More sharing options...
Lazer Posted September 11, 2008 Share Posted September 11, 2008 If the above don't work, have a look at this thread. http://www.cadtutor.net/forum/showthread.php?t=25884 Quote Link to comment Share on other sites More sharing options...
KennethA Posted September 15, 2008 Author Share Posted September 15, 2008 Do you still have access to the old computer? If so, assuming you used default setting for content center location copy the folder from My Documents\Inventor\Content Center Files on the old computer to the same spot on the new computer and see if that helps. you are not using vault are you? That was my problem. I forgot to copy this folder to the new computer. Now everything works perfectly. Thank you very much. Quote Link to comment Share on other sites More sharing options...
Toolish Posted September 15, 2008 Share Posted September 15, 2008 glad to help...been there and had that problem before! Quote Link to comment Share on other sites More sharing options...
