cbuckner Posted August 18, 2010 Posted August 18, 2010 I am currently running AutoCAD Map 3D 2010. Is there any way to add new tabs to the ribbon? Such as mesh modeling... My version runs pretty much the same as regular AutoCAD 2010, just with different features, so if there is a way the work in that one it might work in mine. Any help would be greatly appreciated! Thank you! Quote
ReMark Posted August 18, 2010 Posted August 18, 2010 Yes, new tabs and panels as well as new commands can be added to the Ribbon. Your AutoCAD Customization Guide will have all the information you need to accomplish the task. Quote
cbuckner Posted August 19, 2010 Author Posted August 19, 2010 Thank you! Where can i find the Customization Guide? Quote
Oppie Posted August 19, 2010 Posted August 19, 2010 Run AutoCAD press F1 then on the left choose Customization Guide Quote
memphis710 Posted August 19, 2010 Posted August 19, 2010 Customization guide is here: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ff-5187222b11eeadcdc61-5702.htm,topicNumber=d0e361911 Or... Go to 'Help' and in the search, pop in "customize the ribbon" . With the " " included, go for the top result (also listed as 'customize the ribbon) Create a Ribbon Panel will also help along with most of the results. Cheers Ollie Quote
