harilalmn Posted August 18, 2010 Posted August 18, 2010 Hi All, I have so many drawings in which the xrefs were 'bind'ed instead of 'insert'ing. Seeking a solution I got a Lisp routine from net (Thanks to the person posted it. But I don't remember his name or the wesite I got it from), which is as given below. The problem is that $0$ layers are not getting renamed because I have another layer in the same name. Suppose; I have a layer, Ground Floor Plan$0$A-ANNO-DIMS which has to be renamed to A-ANNO-DIMS Since the drawing has a layer A-ANNO-DIMS, it doesn't allow the lisp to rename it. I have the logic now but I am a zero in lisp. It has to check if the layer exists before renaming. If existing it should merge down the $0$ layer to the standard one. (This part is missing in the lisp routine) Can anyone please change the code to do so? It would be a great help... Here is the code; (defun c:RBP(/ ActDoc Name NewName) ; RemoveBindPrefixes ; Renames layers, blocks, dimension styles, text styles, user coordinate systems, and views ; by taking out the bind as bind prefix ; Example Drawing1$0$Layer1 -> Layer1 (vl-load-com) (defun RemoveBindPrefix (String / Pos LastPos) (if (setq Pos (vl-string-search "$" String)) (progn (setq LastPos Pos) (while (setq Pos (vl-string-search "$" String (1+ Pos))) (setq LastPos Pos) ) (substr String (+ 2 LastPos)) ) String ) ) ;--------------------------------------------------------- (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object))) (vlax-for Obj (vla-get-Layers ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n Layer: " Name " was not renamed.")) ) ) ) (vlax-for Obj (vla-get-Blocks ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n Block: " Name " was not renamed.")) ) ) ) (vlax-for Obj (vla-get-TextStyles ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n Text style: " Name " was not renamed.")) ) ) ) (vlax-for Obj (vla-get-Views ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n View: " Name " was not renamed.")) ) ) ) (vlax-for Obj (vla-get-UserCoordinateSystems ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n UCS: " Name " was not renamed.")) ) ) ) (vlax-for Obj (vla-get-DimStyles ActDoc) (setq Name (vla-get-Name Obj)) (if (/= (setq NewName (RemoveBindPrefix Name)) Name) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName))) (prompt (strcat "\n Dimension style: " Name " was not renamed.")) ) ) ) (princ) ) Quote
ReMark Posted August 18, 2010 Posted August 18, 2010 Perhaps you are referring to the lisp routine written by CAB2k that was included as part of post #10 in this thread at the AUGI website. http://forums.augi.com/showthread.php?t=31759 Quote
harilalmn Posted August 18, 2010 Author Posted August 18, 2010 Yeah I have gone through that. But that was not what I exactly wanted....!! That routine first adds prefix to all XRef Layers like X1, X2, X3 etc.... It does not merge down the layers. In the code I posted here, it does the job perfectly, but I just wanted it to merge down the Layers, Text Styles, Dimension Styles Etc... to the standard ones. Could someone please edit the code to achieve it? Quote
alanjt Posted August 18, 2010 Posted August 18, 2010 This may offer some insight. http://www.cadtutor.net/forum/showthread.php?43156-Too-many-layers!!!-Need-to-merge-them!&highlight=laymrg Quote
