Points along a lwpoly arc
tozjerimiah
Hi,
Firstly I should probably say I am using VBA...
I have created code which will output coordinates for polylines. This info is then transformed to WGS84 & displayed on google maps.
My issue is that google maps will not draw curves. I therefore want to split lwpoly curves into segments of a fixed length (say 100mm), and output the coordinates.
I have the start coords of the arc, the end coords, the bulge. I am able to get the radius, arc length etc, but I'm struggling to determine fixed points along the arc.
If anyone can help I would be very grateful!
Thanks
Toz
VBA does not have any direct access to all of AutoCAD’s curve analysis functionality (unlike AutoLisp, VB.NET, etc). There is a third party hook out there; search for Curve.cls and Vlax.cls. That hook, unfortunately, has a couple of problems that may crop up in certain situations.
It is possible, however, to mimic some of those functions mathematically. For instance, to subdivide a polyline bulge see the attached examples (DWG and XLS).
Edited by SEANT
Removed buggy spreadsheet
Phenomenally useful. Thanks!!
The previous spreadsheet had bugs (thanks for bringing those to my attention, tozjerimiah :)).
This newer version should perform better, I hope. :geek:
FacetBulge_rev1.zip
Edited by SEANT
Yes it works! Thanks.
