bobsy852 Posted August 16, 2010 Posted August 16, 2010 (edited) I have an issue with my AutoCAD 2010. If I zoom in on a line and select it, the grip for the line stays where it should, but the end of the line move away from it's original location. If I dont have the line selected, I can zoom in to the same distance and closer and the lines do not move. However, as soon as I select it, it moves? As this is a bit difficult to explain, I took a video on my phone and uploaded it to you-tube; LINK: http://www.youtube.com/watch?v=CyYh8Hk04Eg (Apologies for the quality, I lack a video card or video editing software) You can see the line however, every time the line seems to move position, all I have done is scroll in or out using the mouse wheel. At one point you see that I do use the grip to move it, however, the location I move the grip to, is not represented by the position of the line. Anyone had any experience with this issue? And if so, can anyone tell me if or how they solved it? My computer details can be found on the left (it's the home system this issue is reffering to, NOT my work system) Thanks everyone! Edited August 19, 2010 by bobsy852 Solved Quote
bobsy852 Posted August 17, 2010 Author Posted August 17, 2010 KiLLiNG-TiME said: Your link isnt working for me ! Apologies KiLLiNG-TiME, it was when I set it up last night. It's working again now after a quick edit! Thanks for making me aware though! Quote
bobsy852 Posted August 17, 2010 Author Posted August 17, 2010 Nope, i find that command to be more of a nuicense than a tool! lol Quote
bobsy852 Posted August 18, 2010 Author Posted August 18, 2010 hmm, is it possibly due to my Graphics card? (Nvidia GT220?) - or would you expect this card to be able to carry out a simple task such as 2D drafting? Quote
bobsy852 Posted August 19, 2010 Author Posted August 19, 2010 OK, after searching the AutoDesk forums, I've found people with similar issues (albeit in 2009) but they suggested turning "hardware acceleration" off. Ok, so i did this and guess what, problem solved.... HOWEVER, I reported previously about the slow mouse issue which occurs in AutoCAD and how solving this issue meant turning ON the hardware acceleration? Is there any way to solve both issues? WOOOO!!! SOLVED!! By selecting the driver name from "Autodesk" to "Direct 3D" it has allowed me full hardware acceleration whilst solving this issue of the lines moving!! :D Quote
ReMark Posted August 19, 2010 Posted August 19, 2010 Two problems solved in one day? Dude, you are on a roll! Glad to hear some good news for a change. Thank you for updating us. From now on, if anyone has a similar problem we expect YOU to provide them with the solution. That's your mandate now. LOL Quote
bobsy852 Posted August 19, 2010 Author Posted August 19, 2010 I know! Well i solved the mouse problem a week back but the solution to this problem brought it back! Me too to be honest! haha no problem, thought it makes ir more obvious for anyone looking for this same issue to see that the answer is in here! Haha, well i'll always try my best! To be honest it was all a lot of trial and error playing with the settings and flicking through google results! Got there in the end though! I think that's 1 system sorted anyway (for now ) I'm interested to know the difference between using the Atuodesk driver instead of the Direct 3D driver if anyone could please tell me? If there is any different at all? Quote
ReMark Posted August 19, 2010 Posted August 19, 2010 I believe the drivers are written specifically for AutoCAD by the maker of the graphics card. Quote
yoyomankind Posted December 6, 2014 Posted December 6, 2014 bobsy852 said: OK, after searching the AutoDesk forums, I've found people with similar issues (albeit in 2009) but they suggested turning "hardware acceleration" off. Ok, so i did this and guess what, problem solved.... I'm working with 2015 and believe I have come across the same issue. Unfortunately I already have hardware acceleration turned off. I've tried searching Autodesk forums and google, and this was the only post I could find regarding the issue. Any further suggestions to help fix this would be appreciated. Quote
SLW210 Posted December 8, 2014 Posted December 8, 2014 Would help to know your Graphics card, current driver used and all other Computer specifications. Quote
yoyomankind Posted December 9, 2014 Posted December 9, 2014 It appears that switching my visual style from "Shaded" to "2D-Wireframe" fixes the issue, though I'm not entirely sure why. The computer is an Acer Aspire 5920: Intel Core 2 Duo T5450 (1.66GHz) 2GB DDR2 Intel® 965 Express graphics card Quote
SLW210 Posted December 9, 2014 Posted December 9, 2014 It would seem by those specifications your CPU pretty slow for 2015, you are at the bare minimum with 2GB RAM and you have an integrated graphics card. That Laptop came out in 2007. You can upgrade to 4GB RAM and a dedicated Graphics card was an option, but you would still have the Intel Core 2 Duo T5450 (1.66GHz), you may as well just get a new Laptop or a Desktop, Laptops to run AutoCAD efficiently are not cheap. Quote
