Ahankhah Posted August 13, 2010 Posted August 13, 2010 Hi, I know how to open and edit an existing excel file from inside viaual lisp code, but am not able to create a new one:?. Has anybody any idea? Mehrdad Ahankhah Quote
rkmcswain Posted August 13, 2010 Posted August 13, 2010 Check out the code in this tip, specifically the "(init-excel)" function http://cadtips.cadalyst.com/export/export-text-a-drawing-excel-spreadsheet Quote
stevesfr Posted August 13, 2010 Posted August 13, 2010 RK, When I try and run Txt2xls program, I get the following... Command: TXTEXC Connexion avec Excel 2000 Erreur : bad argument type: VLA-OBJECT nil I guess program is not friends with my Excel 2000. What needs to be modified? Thanks.. S Quote
Lee Mac Posted August 14, 2010 Posted August 14, 2010 This should point you in the right direction: http://web2.airmail.net/terrycad/LISP/GetExcel.lsp Quote
stevesfr Posted August 14, 2010 Posted August 14, 2010 thanks Lee, I forgot about GetExcel and to load it ..... Steve Quote
Ahankhah Posted August 16, 2010 Author Posted August 16, 2010 rkmcswain, Lee Mac, thank you very much. Mehrdad Ahankhah Quote
