Floor Sink????
i work for a large manufacturing company as a drafting intern. bassicly i run around a 1000000 sq2 facility with a clipboard and a drawing verifying that what was drawn 10 years ago is accurate. that said on one of my plumbing drawings it talks about somthing labeled FS. when you go to the legand to look it up it says its a floor sink
they are located on the drawing near every AHU and are only about 6x6 but my boss thinks there supposed to be like an actual sink or a mop sink
6'x6' or 6"x6"? A floor sink is more or less a drain that is placed into the middle of the floor. It is not actually a sink that is in the floor, but it does allow water to flow through, and is more like a bathtub or shower drain than a sink. You can not get water out of a floor sink, nor do they have handles and spouts. They are simply there for the purpose of draining water, not getting water. Are there any drains located where the plans call for it?
wow that was a speedy response thanks alot
... yeah all the drains/ floor sinks match up on the drawing
thanks again for the response it was very helpuful
I have seen this words for the same thing. fd-floor drain & fw- floor waste but it is intresting to know that in can be called fs-floor sink also.
6"x6" or so sorry i didnt see that the first time around.
so it definately is floor drain or floor waste, whatever you call it
Does nobody use Google any more? :(
(Don't weaken Dipali, only another 2 posts)
eldon,
did you find this image from google. if yes than give me some tips on how to search. i have been trying to search some details since few days. i nee dsome details related to swimming pool. like overflow channels etc.
For this particular one, I just typed floor sink into the search window and that is what it found. In fact I just tried the search on CadTutor's home page (top right), and it came up with the same thing :D
One tip is to enclose the words being used to define the search in quotation marks. So, for example, a search for floor sink would be typed as "floor sink". Leaving out the quotes would return results based upon the individual words as well as the two words grouped together (i.e. - a lot more "hits").
