Please Help,
I am working in a machine shop where the g-codes deal with only X & Z axis tooling
The drawings I do are of a 2D profile of the parts to be tooled, and I basically mimic the tooling paths on a 2D drawing, to show the cuts to the part to be made.
I currently do this by converting the G-Codes on paper to match the default WCS.
I have been experimenting with the UCS system trying to align it so I could basically type in POINT commands exactly as the appear in the program and have it plot the points along the tool path.
But I am having difficulty when rotating the UCS, and need a shove in the right direction...
So, in effect I need to learn how to rotate a UCS I have created to appear as follows;
Z
|_____ X
Make sense?
Thanks for any help
You want the Z axis to be pointing towards the top of your screen. Is that correct?
Yes that is correct.
And the X to the right.
That will allow me to type points directly out of the program to create my tool path
Well then you would want to rotate about the X axis minus 90 degrees. From my AutoCAD text window:
Current ucs name: *TOP*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
: X
Specify rotation angle about X axis : -90
Ok, I am trying the example you provided.
When I rotate the UCS I get the "Broken Pencil" Icon which as I read indicates the drawing view is perpendicular to the UCS plane and you can't draw.
Am I understanding that correctly?
Here are the steps I am taking, please advise what I am doing wrong;
TOOLS> NEW UCS> ORIGIN.... (I pick my new origin point as the Zero Refernce point of the Part I'm working on)
then I do..
TOOLS> NEW UCS> Specify Rotation Angle About X Axis> -90
Then I get the Broken Pencil Icon.
So if I understand correctly, the X axis has been rotated perpendicular to my drawing view (Model View)?
How would I get the UCS to rotate, but still allow me to draw on my current model view, where my other objects are?
Here is a screen shot.
Notice where the UCS is located and the code I need to use.
Here is the rub... the (current) X axis is the "zero" horizon and from the tool's point of view... anything above the X axis is negative, and below it is positive.
I need to get Autocad to set a UCS to allow me to type POINT coords in that will behave correctly.
In this application, the tool moves up and down in the X axis, and left and right in the Z axis, with the UCS being the 0,0 point with negative above the horizon
Edited by rickhebert
rickhebert,
Autocad assumes that all drawing will be done in the XY plane. Maybe what you need is to do all your work in XY, then 3drotate everything into XZ as a final step.
calcad after much experimenting I believe that is the only solution. Thanks for the replies.
