HI,
I have been using Windows Copy/Move by using ctrl+dragging any object (except the grids) or simply dragging the object. However, one limits I noticed so far is that I can't go beyond the actual screen. I have to move the objects twice/thrice in order when the destination is far away. This is not the case with the MOVE/COPY SELECTION command where I can pan. Is there any solution to the problem that I am missing?
Thank you in advanced,
Nicolas.
You should be able to use your mouse wheel to zoom in or out while dragging objects
  • 2 months later...
Sorry for the late reply but with windows move/copy type, I can't zoom in/out with the mouse wheel at the same time. The objects only move/copy within the scope of the available display limit.
Correct you can't zoom when doing it this way. To be honest i would change the way you are doing it and use the COPY command this gives you more flexability and allows you to pan / zoom around your drawing whilst the command is active.
You could try using the Aerial View feature (command line: dsviewer). Refer to your Help file for more information.
